Question about Whirlpool Duet GHW9150P Front Load Washer
My towels smell musty and I have used he washer cleaner
My towels smell musty, i have used washer cleaner, i have cleaned the rubber seal on the door and i still have the same problem
  • Bruce Hathcock May 11, 2010
    First thing to do is buy a gallon os super clean at Wal Mart, their the cheepest then was it down with the super clean and use rubber gloves then run the machine with 1/2 cup super clean and 1/2 cup of fabreeze and run it threw one wash cycel see if it smess bettr after that.
  • 460 Answers
This smell is very commun with this washers but is unexeptable therefore is an attorny helping with issue.
Please read this web side contact them and please let me know the results.
http://www.lawyerseek.com/Practice/Consumer-Protection-C21/Whirlpool-Duet-Mold-Problems-P172/
Your rating and VOTE is very important to me....
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you.
please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Posted on Jul 25, 2009
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
My washer has a mildow smell and my clothes smell musty, especially towels!
This is a comin in all front loaders. It it caused by two things not using HE soap and keeping the door closed when not using it. The only way to get rid of the smell is to run 3 to 5 cycles with bleach and no clothes or use a washer cleaner. Most large hardware stores carry them. Once the smell is gone be sure to leave the door open when you are not using it and wipe out the gray boot(gasket/seal) after using.
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Jul 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
My Elite washer has a musty odor. I have run an
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Foul odor
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold? behind seal on whrilpool duet front load.
Run it a couple times on hot water with bleach in it. Should help. Also run through with dishwasher detergent in it. This helps clean too. I leave door ajar to allow air in washer. You can also purchase cleaner just for this at parts place.
Nov 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
423 people viewed this question
Dan Webster
Dan Webster
Sal De
