Question about Uniden Computers & Internet
Is there a antenna that will boost the signal for my udrc57hd cameras from Uniden? Uniden says they don't have a product but that there may be a third party vendor that does.
toto
  • 425 Answers
SOURCE: AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Posted on Sep 19, 2005
Bubbabear64
  • 2794 Answers
SOURCE: low signal
The only other way to boost the signal is to disable the one built in and use a usb type adapter. They act more like antennas that way. If you have a pcmcia card slot on the side of your notebook there are come wireless network adapters out there that have an antenna on them as well.
Depending on what router your using, most routers can have their antennas upgrades as well.
Posted on Jun 21, 2008
SOURCE: Will Accel-a-writer 4n work running Leopard 10.5.6?
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Posted on Jan 16, 2009
realmacoi
  • 18 Answers
SOURCE: am antennas
Hi, to all. There are currently two types of Bose Wave Radio system available in the market. The first one being the WRCD with the top loading CD mechanism. This unit does come with the Antennae cable inside the box and this should sort out your problem. Another option is using an outdoor aerial antennae and connect this to the antennae port behind the unit. The second one is the new Wave Music System with the front loading tray mechanism. This system uses a unique concept of using the electrical cable included in the box and utilise your electrical pwoer line as the antennae receptor. I recommedn to keeping the pwoer calbe fully extended. Another solution for this is that Bose service centers do have a specific spare parts calbe called the AM/FM antennae cable for WMS which you can simply buy for around 20$ I assume. this basically bypases the power calbe and routes antennae reception through this minicable (brownish colored RJ calbe).
Glad to be of service...
Posted on Apr 08, 2009
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
How to boost the signal Motorolla CP200XLS
First, check your programming to see you are operating at full power (4W UHF or 5W VHF). Secondly, use the standard 6" antenna which came with the radio. (Stubby antennas will reduce range). Third, educate users to hold the radio with the antenna perpendicular to the ground. Tilting the radio to the side will reduce range. Fourth, have your radio, if older, retuned and aligned to bring it back to factory spec. Lastly, if range is still a problem, you might check to see if there is a system or repeater you can utilize in your area to extend the range of your radios.
Best regards.
May 13, 2014 | Motorola CP200 Two Way Radio
Need to pair my udr444 cameras to my pc
Most security cameras put out an analog signal....whereas PCs need a digital signal. It may work if you find a program to convert the analog signal to digital. If I were you I would just buy a small flat screen tv and use the Audio/Video input.
Mar 20, 2014 | Uniden UDR444 Video Survailance System;...
Signal issues
If the antenna on the camera can be removed then there are long range antennas available that will increase the signal strength. You have to if the camera is transmitting on 2.4 ghz or 5.8 ghz before you look online for an antenna. just google 2.4 ghz antennas for a list.
Jan 08, 2014 | Uniden UDR444 Video Survailance System;...
What of the model of my uniden camera
What is the problem, Don;t operate at night or without light, test make simulator with one lamp directly and other in a box close.
And review the specifications and modes to use this cam
May 31, 2013 | Uniden Wireless Outdoor Camera With Night...
How do i increase wi-fi signal strength
There are only a few ways to increase signal strength ..move closer to the source (the router) , get a bigger antenna or boost the signal...you can boost the signal with foil in the shape of a parabola around the router antenna or make one out of a vegatable strainer that will plug into the laptop(this one works best )especially for picking up your neighbors WIFI
http://www.focus.com/briefs/mobile-wireless/home-made-wifi-antenna/
Dec 27, 2010 | Computers & Internet
Ive got a Uniden BC248 CLT Base Scanner. In the back of it, there are two holes for input/output of some sort, What is the diference in the am radio antenna vs. the antenna ?
Your scanner has four connections on the back. Looking at the rear, from left to right, are the power jack (10 volts AC, you need an adapter for this), an external speaker jack, the AM antenna connection, and the scanner antenna jack.
The AM antenna jack is for the reception of AM radio station signals. The scanner antenna jack is for police/fire etc, as well as FM signals.
In case you don't have a manual for your radio, it is available for free here:
http://www.uniden.com/pdf/BC248CLTom.pdf
May 09, 2010 | Uniden BC248CLT Base Scanner
Low wireless signal wbr 2310 on signal strength
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Low signal
The only way to boost the signal is to upgrade the internal wireless card to a card with more range. Research the various Broadcom and Intel wireless cards and find one that meets the range you need. Most of the cards are interchangeable, so even though it may not have been offered for your machine, it will work, with the proper drivers.
Jun 21, 2008 | Dell Latitude D620 Notebook
Computers & Internet Logo
23 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Avishek Samaddar
Avishek Samaddar
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
