Question about Coffee Makers & Espresso Machines
Only getting a partial cup of coffee - Coffee Makers & Espresso Machines
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Is my Keurig coffee maker
For some reason, your post is under microwave...????
try doing a vinegar/water cleaning..
Run 1/2 cup vinegar to full tank of water...keep out the k-kup..just keep running until empty..then run fresh tank of water thru. until bad taste is gone...
Posted on Dec 18, 2010
heatman101
  • 43501 Answers
SOURCE: I have a new B60 keurig coffee maker. Can yuo help
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
nicklemarr
  • 296 Answers
SOURCE: My coffee maker is only making partial cups. Have
Make sure you are filling it up to the correct spot, if so, then the potentiometer may be off, in which case, you would need to send it away or take it apart and fix it.
Posted on Mar 21, 2011
rohntech
  • 422 Answers
SOURCE: I have the coffee maker set to 2 cups. After 1 cup
Yes you programmed it unaware, the machine will follow what you instruct on it. So change the program setting and try it again.
This advice will gonna help you.
Posted on Mar 31, 2011
Why does my Keurig only fill partial cup when it is on large cup and only seems to happen with a bold coffee
According to my Platinum manual your exit needle may be partially plugged clean carefully with a straightened paperclip. Run a couple cycles without a K-Cup inserted. This should fix your problem.
Oct 04, 2014 | Keurig Elite B40 Coffee Maker
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
The machine is brewing more than a partial cup it says on the display DE-Scale?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 11, 2011 | Keurig Platinum B70 Coffee Maker
It's brewing partial cups. We've descaled, checked the K cup, and run water through without the K-Cup
heatman101
Jun 15, 2011 | Keurig B60 Coffee Maker
On my Keurig coffeemaker, I de-scaled it with vinigar twice, but I now get partial cups when I try to brew. The amount of coffee is reduced with each brew.
heatman101
Jun 13, 2011 | Keurig B70 Coffee Maker
Mar 25, 2010 | Keurig B60 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
