Question about Casablanca Fan (3845T) Brushed Nickel Ceiling
Can I use a remote for a hardwired Casablanca ceiling fan/light?
I have a Casablanca ceiling fan/light that is hardwired to a wall control panel. Is it possible to get a separate remote for this and program it if needed as well?
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
MN_Jack76
  • 45 Answers
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Posted on Oct 17, 2009
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
MN_Jack76
  • 45 Answers
SOURCE: i have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Posted on Feb 09, 2011
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
"Ball Ceiling Fan" - hardwired wall switch only turns on or off, no speed control or light control, stuck on "high" and light "on" when switch is in "on" position.
The most likely cause (and the one I've always encountered) is the switch/controller nit wears out from electrical arcing that burns the contacts or temperature kills electronics on "soft" speed controllers
Mar 03, 2013 | Modern Fan company ball ceiling fan
Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
Here's Casablanca Support phone number:
Call Toll Free: 1-888-227-2178
Hope this helps!
Aug 03, 2011 | Casablanca Fan 3845Z Ceiling Fan
I have a Casablanca "trident"
Hello Duke,
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Fan won't go on
Aug 07, 2008 | Casablanca Fan Televison & Video
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Casablanca Fan (3845T) Brushed Nickel Ceiling Logo
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
