Question about Garden
How to install drive motion belt on model yth2348
3 Suggested Answers
crayzeetrayn
  • 837 Answers
SOURCE: replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Posted on Jan 19, 2009
Husqvarna yth2348 drive belt replacement
I would start by taking the deck off completely
Jul 21, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a model yth2348 mower. How do you adjust the speed of the mower. I have changed the drive belt but it still runs slow.
hydrostatic transmission there is only one throttle setting and that is WFO. if it is running slower than it used to, and the drive belt is snug, then you are looking at a failing transmission.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I want to install a new motion drive belt on my Craftsman Model # 917.275684. (24hp, 42 cut) The belt part number is 140294. I removed the old belt by cutting it in two and now I can't get the new...
First thing is to check the new belt length against the old belt. Should be close, maybe old belt just a little longer. Then when you were trying to put the belt on did you set the brake like parking, that should take the tension off of it for you.
I hope this helps you out.
Aug 08, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I get a diagram to show me how to put a serpentine belt on a 1998 Ford Escort Station Wagon?
you ask here. Please rate highly
SECTION 303-05: Accessory Drive 1998 Escort/Tracer Workshop Manual
REMOVAL AND INSTALLATION Belt -2.0L SPI Removal
  1. Relieve the drive belt (8620) tension.
    • Use a (A) ratchet or breaker bar inserted in the square hole in the drive belt tensioner flange.
    • Rotate the (B) drive belt tensioner (6B209) in a clockwise motion to release belt tension.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the engine splash shield.
  1. Remove the drive belt from the accessory drive belt routing pulley (6C348) and then the remaining accessory pulleys.
Installation
  1. Position the drive belt over the accessory pulleys. Raise and support the vehicle if necessary; refer to Section 100-02 .
  1. Install the engine splash shield.
  1. Rotate the drive belt tensioner in a clockwise motion.
  1. Slip the drive belt under the belt idler pulley (8678) and release the tool. Remove the tool from the drive belt tensioner.
  1. Accessory Drive-With A/C
  1. Accessory Drive-Without A/C
Belt -2.0L Zetec Removal
  1. Raise the vehicle on a hoist; refer to Section 100-02 .
  1. Use a 13 mm wrench to rotate the drive belt tensioner (6B209) in a clockwise motion.
  1. Remove the drive belt (8620).
Installation
  1. Position the drive belt on all the pulleys and the drive belt tensioner.
Item Part Number Description 1 10300 Generator 2 19A216 Drive Belt Idler Pulley 3 3D673 Power Steering Pump Pulley 4 8509 Water Pump Pulley 5 6B209 Drive Belt Tensioner 6 19703 A/C Compressor 7 6316 Crankshaft 8 19A216 Drive Belt Idler Pulley 9 8620 Accessory Drive Belt
  1. Install the drive belt and gently release the drive belt tensioner.
    • Run the engine for several minutes to seat the belt into the pulley grooves.
Jul 09, 2011 | Ford Escort Cars & Trucks
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48" Husqvarna Loss of drive
First of all, use only OEM belts2.gif from a dealer or in the case of Craftsman, from Sears or direct OEM replacement belts from a lawn mower2.gif repair dealer.
If you are using a generic "hardware store" belt, chances are you are getting a "fractional horsepower belt" which is made for low torque electric motors and they will not withstand the torture a lawnmower puts on them.
When installing the new belt, make sure all pulleys are clean and have no bent spots, burrs or cuts in them. Make sure that any idler pulleys spin freely and also make sure that you get them on the correct side of any belt guards.
The transaxle IS a sealed unit and is not servicable There are no parts available for it and no parts lists. Your only remedy is to take it to a dealer to have it replaced if it is indeed defective
You can go to this link, click on support and download a manual for your model number which gives belt routing, parts listings and a lot of good information pertaining to your tractor:
http://www.husqvarna.com/us/homeowner/home/
Sep 03, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
