Question about Boating
How do i tilt my 25hp 4stroke outboard motor - Boating
  • 157 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
SOURCE: OUtboard motor tilt not working
There should be a hydraulic bypass valve screw on the tilt assembly. Usually a large slotted screw driver is needed to loosen the valve. The motor can now be lifted manually, but not with ease.
Posted on Jan 26, 2009
  • 86 Answers
SOURCE: I have a 1994 150 hp Yamaha outboard motor with
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Posted on Aug 03, 2009
  • 57 Answers
SOURCE: cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
Posted on Oct 15, 2009
muffteck
  • 202 Answers
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
I have a 50 Yamaha 4stroke outboard motor,it starts well but caughs or hesitated after its started,it has no power
Maybe a partially plugged fuel filter? Do you smell gas? if so, check lines for leaks
Jul 11, 2016 | Boating
Suzuki outboad 6hp 4stroke
outboard motor yes ? only run in a tub or water attachment turned on before starting ! after 2 or 3 min the choke should be able to go off ! if not then remove the carb and clean jets etc with carb cleaner ! been stood a while ? fuel older than 5mths is off so replace also ! ??
Apr 20, 2014 | Motorcycles
2003 yamaha 25hp. outboard four stroke no spark at plug how do u check coil and control modgul
Hi Drxxxxa, for more information about your question please visit the website below. Good luck and have a nice day.
DOWNLOAD 25HP Outboard Repair Manuals
Jun 14, 2012 | Motorcycles
Mariner 25hp 2stroke outboard. runs fine when
With what you said.get the water pump done.A little bit of rubber is cheaper than metal.If the motor has a few years on it,the pump does need to be replaced.If the motor overheated after a few minutes,the pump needs replacing now.Yours sounds like it's on it's way out.A bit of sand etc. can do a fair bit.Hope this helps
Sep 09, 2009 | Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Boating Logo
29 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
