Question about Stihl Garden
Throttle cable replacement on stihl fs 83 trimmer
  • 57 Answers
SOURCE: stihl string trimmer shaft viberation, how do you
Most of these type units only allow you to replace the entire shaft assembly. Have one myself and could not get just gearbox.
Posted on May 19, 2009
panilling9
  • 284 Answers
SOURCE: Looking for printable copy of owner's manual for
go to www. stihlusa.com
click on product instruction manuals (under chainsaw picture)
click on download or order manuals
scroll down to trimmer section and find your fs80 and fs 85
click on it and it should come up and be what you were looking for
Posted on Jun 05, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Posted on Sep 07, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
THE FS 46C WEEDEATER WILL IDLE JUST FINE, BUT WILL NOT REV UP WHEN PULLING ON THE TRIGGER. THE THROTTLE CABLE IS NOT DISCONNECTED AND THE CARB IS CLEAN. ANY SUGGESTIONS?
easy... if the carb adjustments are still factory set the you just need to replace the muffler screen or also called a spark arrester.it covers the muffler exit....
Sep 13, 2012 | Stihl FS 85 Weed Eater
I need to see how to replace the throddle cable assembly on a stihl fs 75
Here is a link to the parts manual, there ate a few different types of throttle setup.
Oct 05, 2011 | Stihl FS 85 Weed Eater
Garden Logo
35 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
