Question about In Office Equipment & Supplies
Is cutting lines of print in half and sometimes less than half
CarlGehrke
  • 169 Answers
SOURCE: When printing some lines don't
Try printing out the test page from the printer, this will show you if any of the inkjet holes are getting plugged. If you can't print a test page without the skipping try changing the ink cartridge(s), the test page will show you which one is clogging.
Carl
Posted on Dec 10, 2008
SOURCE: 4580 all in one less than 6 mos old started printing half lines
try to clean the print heads of the ink cartridges. you can do it in the HP solution center. you can run it through all 3 tests so you make sure its clean. if it doesnt work after that, your ink cartidge level might be off, because i hear they never work half the time anyways. i would buy new ink if the cleaning the heads does not work. good luck!
Posted on May 23, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
  • 4 Answers
SOURCE: My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
Posted on May 26, 2010
Testimonial: "thank you i still have issues i copied a picture and i stll had the problem white lines accross the entire page horizontally about 1 inch apart 11 of them"
  • 10 Answers
SOURCE: Last line cut off
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Posted on Oct 02, 2010
HP Officejet 5600 All-in-One series
Is your question the top or bottom one? You have cleaned the metal contacts on both the cartridge and on the machine with a soft cloth, right?
Aug 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Clips or cuts off half the page or just last line
hi, dont worry I will guide you throught the steps to fix this issue.
Please follow the instructions provided below
1. open Ms word
2. click on print
3.click on properties
4.click on pages, and chage the paper setting this would resolve your issue.
Aug 20, 2009 | HP DeskJet 6450 Printer
When printing some lines don't print properly-appears to be just the top half or less of the line will print. It seems it happens every 3rd or 4th line, but has done it on the second line also, so is not...
Carl
Dec 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Nov 12, 2008 | Office Equipment & Supplies
Printer cuts off lines
I had this exact same problem - probably about a week after I put in NEW cartridges. I took them out, wiped the bottom off with a tissue (black and color) and put them back in. Did a test print and everything looks fine now.
Oct 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP 7410
do a self test on the printer and see what that looks like.
Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
23 people viewed this question
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
