Question about Coleman Sport & Outdoor - Others
How to access the top lift winch on a 1996 coleman pop up camper.
motor1258
  • 6674 Answers
SOURCE: ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Posted on Aug 14, 2008
  • 13433 Answers
SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Posted on Oct 26, 2008
  • 37 Answers
SOURCE: best method to repair cracks in the white
"JB Weld" Might Work.. Then Paint Over to match Camper
Posted on Jul 01, 2009
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Posted on Jul 02, 2009
  • 13 Answers
SOURCE: I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Posted on Oct 27, 2010
How to tighten cable on pop up camper
Oct 26, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
How can I get a 2000 coleman sun valley pop up camper owners manual
Unsure if this is the same model: free manual online
https://cdn.shopify.com/s/files/1/0273/4347/files/2000_owners_manual.pdf?13230720448029520186
Parts manuals - possibly different model:
http://www.campersolutions.com/home/coleman-parts-manuals/2000-coleman-popup-camper-repair-parts-manuals
Apr 22, 2018 | Coleman Sport & Outdoor - Others
Need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
Apr 23, 2012 | Coleman 10' X 10' Sundome Tent 9160K101
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
Jun 29, 2009 | Sport & Outdoor - Others
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Sport & Outdoor - Others Logo
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
