Question about Radio Communications
My wireless ink'd earbuds are flashing blue and red and it won't connect how do I fix it?
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Posted on Nov 22, 2012
Can i pair vivitar bluetooth earbuds to my laptop
you can try this option. depending on the model.
How do I pair my Vivitar earbuds?
According to the manual, the procedure is as follows:
  1. Turn the headset off.
  2. Press and hold the MFB (Multi-Function Button) for 6 seconds until the LED flashes red and blue alternately and you hear a beep.
  3. Search for Bluetooth devices on your phone and select the PHBT5.
  4. Enter 0000 as the PIN if asked.
or this
  1. Pair and connect the headset. Hold for 7 seconds until the red and blue LED. ...
  2. Charge the battery. ...
  3. Turn on Bluetooth on your phone and pair with the headset.
  4. 2011 ARCTIC (HK) Ltd.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Feb 04, 2018 | Radio Communications
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Wireless bluetooth won't connect to phone
May not be compatable with ur phone check the internet site for the bluetooth to see if its compatable.
Nov 22, 2013 | Plantronics Discovery 640E Wireless...
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
Can you say if Plantronics 220 is compatible to work with blackberry 9630?
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud.
Jun 20, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I was wondering how to hook up a Bluetooth headset to a Samsung Gravity
Jun 29, 2010 | Samsung Gravity SGH-T459 Cell Phone
I replaced my phone and now i cant pair my plantronics explorer 233 it can't locate the device help me please
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud. Then you may have to enter a connect code (usually 0000) for the pairing to enable. Once they are paired....enjoy!!
Jun 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pin #
When you very first get the device you need to charge it exactly AND I MEAN EXACTLY (NOT MORE & NO LESS THAN) 14 HOURS! This is because it is from china and it is a way of programming the earbud bluetooth device. good news ... this may just work for ALL of the EMERSON BLUETOOTH DEVICES! So.... don't forget to make sure you hold down the answer/end call key until fast flash alternates blue to red and red to blue (ETC).
PASSCODE IS '0000' once again 14 hours... no less and DEFINALTEY NO MORE!
GOOD LUCK!
Jul 15, 2008 | Southern Telecom Emerson Bluetooth Headset...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Radio Communications Logo
639 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
