Question about Building Materials
Garage door won't open unless held down. Green light goes off after closing door.
  • 3 Answers
SOURCE: how do you bypass sensors for craftsman garage door opener
The sensors are safety features so the door won't close on someone. When you hold the wall button down it's over riding the sensors, therefore it works when you hold down the button but will not work when you tap it or use the remote. Line up the photo cells so they stop blinking. If they're blinking they think something is in the way...hence not closing. If you can't get them to line up and stop blinking one may be defective. Contact the manufacturer and see if you can purchase a replacement set. They usually aren't too expensive, maybe $20/$40.
Posted on Apr 01, 2008
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
Door wont close unless the key pad is held down day or night time
the photo eyes are out of alignment or have dust on the lenz, clean them off and align them, and your proplem will go away
Sep 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of the trip sensors shows a yellow LED, the other sensor shows a green LED. The door will not go down unless the close button is held. A force down adjustment does not help. Even when disconnected from...
If when the door reverses the main light flashes 10 times it is a sensor problem. If not it could be the RPM sensor board which is a small printed circuit board just in front of the motor.
Jul 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
if you obstruct the photo eye does the light flash ?
Jun 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
51 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
