How to remove jammed filter? - Washing Machines
Remove filter from Beldray vacuum cleaner
It would be best to call the Dyson Co. directly as any attempt to remove a jammed part could make the unit unusable. If in Warranty, you may get a replacement.
Apr 03, 2014 | Dyson Vacuums
Why dishwasher started making growling sound all of a sudden?
Possibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Remove any debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.Loaddishes and re-check
Apr 09, 2012 | Maytag Dishwashers
How do you take the filter out to clean it? Front Loader Washing Machine LG
I assume you mean the filter behind the little door down the bottom. You open the door and unscrew the cover to remove the filter. if it won't come then it must be jammed. Try using a pliers to carefully work away at it . It probably has coins etc jammed inside. I have broken these by trying to remove them, but it has to come so if this happens it doesn't cost much for a new one good luck
Mar 05, 2011 | LG Washing Machines
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Canon- Filter jammed
You can try this but at your own risk. It is likely you will damage the filter, its threads or the lens' threads.
Something IS VERY LIKELY TO GET DAMAGED IN ATTEMPTING THE FOLLOWING. Please USE YOUR OWN COMMON SENSE and DISCRETION:
Recommend that you remove the lens from the camera to avoid damaging the camera.
Option 1: Wrap a rubber band around the filter ring only and see if you get a better grip.
Option 2: Use a sharp nosed pair of pliers and grip only the filter and *PULL* (not push) in the anti-clockwise direction when facing the lens towards yourself. This is likely to damage the filter or the lens thread, but may remove the filter.
Nov 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
How do i remove the oil filter on my 2007 ddis
You can use an oil filter wrench or get a rubber handled wrench that you can open jar lids with and use that instead to turn counter-clockwise to remove. If stuck, jam a screwdriver through it and turn it.
Sep 09, 2009 | 2007 Suzuki Grand Vitara 4WD
Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
