Question about RCA Televison & Video
Codes to program rca tv/vcr remote - RCA Televison & Video
    Top Expert:
  • RCA Master
  • 36,467 Answers
The codes are in the remote control.
Posted on May 09, 2017
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I have a sony bravia tv and and rca universal remote need the code numbers
TV/VCR Combo.
For power on, these products require programming TV
codes on the remote control. For Sony, use TV code 0000
and VCR code 0032
Sep 29, 2013 | RCA 3-dev Universal Remote Remote Control
I want to use rcr311w remote for rca t25208 tv but couldn't
This remote does not handle combination TV/VCR devices. You will need a different remote. You can get an exact replacement remote here: http://remotes.com/store/rca/t25208.html .
It will control the TV with the code 1000 (most likely). Other RCA TV codes are 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187. The manual and code list for the remote are available here: http://www.rcaaudiovideo.com/support/?kw=RCR311W . The VCR part uses a code that isn't programmed into the remote. (Remotes generally only have codes for devices released 6 months or more before the remote was programmed. Many of the older RCA universal remotes never had their coding lists updated to include combination units.)
BTW, the manual for your TV is here: http://www.managemylife.com/mmh/owner_manuals/14623/RCA-TV-VCR-or-DVD-Combo-L0109139?brand_name_search=entertainment .
I wish that I had better news.
Mar 02, 2011 | RCA T25208 25 in. TV/VCR Combo
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
011,026,027,028,029,030
031,032,037,042,053,064
Here are some instructions as well for your RCA Remote:
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Hope that helps.
Aug 22, 2010 | RCA Universal Remote Control
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 07, 2009 | RCA Universal Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
No code search button
Turn on your TV, hold down tv or vcr/dvd depending on what you want to program. Then enter the codes this site gives you. http://remotefinder.rca.com/default.aspx?site=rca. Then release tv or vcr/dvd and see if your remote will change the channels.
Feb 18, 2009 | RCA RCR412C Remote Control
Need to program my TV-VCR 9" combo using the RCA remote RCC311w
Try pressing the VCR button and see if that works.
Alternatively use one of these codes (For RCA VCR):
2000, 2003, 2007, 2013, 2021, 2022, 2055, 2056, 2082, 2083, 2084, 2085, 2086, 2087, 2088, 2089, 2090, 2091, 2100, 2107, 2115, 2120, 2125, 2133
Two methods of programming RCA remotes:
A: If your remote has a "Code Search" button:
Press and hold the button until the light comes on and stays on, then release and press "VCR", Enter the last 3 numbers of the code (no using the first number 2).
B: No code search button:
Press and hold the device key, while holding it put in all 4 numbers of the code, then release the device key, the light should go out.
Dec 21, 2008 | RCA T09082 9 in. TV/VCR Combo
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
