Question about Sony Televison & Video
I have a Sony KDL-XBR4. Working fine when I went to bed last night. Today I have picture but no sound. Have Sony sound system. Switched to TV speakers and no sound.
  • 5568 Answers
SOURCE: Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Posted on Jan 03, 2009
  • 1077 Answers
SOURCE: My Sony KDL-46 Xbr4 picture flickers and there's
The blinking light is a problem code.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you blinking light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
  • 30 Answers
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Posted on Sep 26, 2009
Testimonial: "A quick one to respond with a good answer to the problem."
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Sony SXRD Projection TV
I have the 50" SXRD TV and have expereienced many of the same problems as other owners. Sony replaced the optical block at no charge after the screen yellowing effect took place. Recently, I have the TV shut down with the flashing red light blinking in sequences of 4. After unplugging the TV for a few minutes, replugging it, and turning it back on, it worked again. However, this was not a pemanent solution as the problem returned. After reading several posts here, I turned the TV to look into the fans and voila, the one on the left was not spinning.
I took the back off of the TV (9 screws) and took apart the fan housing to vacuum everything. In addition, I vacummed everything else I could see. After putting it back together, the problem was solved. Save yourself a repair call. Get out a phillips screwdriver and a vacuum cleaner. Thanks to the posters on this site!!
Posted on Dec 28, 2009
My sony trinitron is blinking red and won't turn on
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KDL-40bx450 no sound
Two things to do:
First see if you have sound with a DVD etc connected to a rear input.
Second look in the menu to make sure speakers not switched off or to external
Dec 13, 2012 | Sony KDL40BX450 40" 1080p LCD TV...
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My 46" SONY LED has no sound coming out now.
Hi this sounds very much like a dry or bad solder joint probably on the power supply PCB, if you have the necessary soldering skills and a magnifying glass you maybe able to fix this yourself.
The picture below shows an example of what a dry joint(s) looks like, if you are able to solder and understand the risks in taking apart your TV you could save yourself a good few bucks!
Always make sure the TV is unplugged and please be aware that voltages can still be stored even when the tv is turned off, if in any doubt or you are unsure about attempting a repair please consult a qualified TV technician.
Hope this helps
Feb 10, 2011 | Sony BRAVIA XBR46HX909 46 in. 3D HDTV
Sep 26, 2009 | Samsung 50 in. Plasma TV
hi the lamp has gone £ 80 to 100 pounds to replace
Dec 15, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Viewsonic problem
Have you checked the SCART leads?
Usually seems to be the cause of this kind of thing.
Nov 07, 2008 | Televison & Video
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Working fine next day red light on solid
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
Open Questions:
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
