Question about Cameras
I have a 51h84 that i cleaned the screen and mirror on, now picture is missaliened. how to fix.
Looks like picture is coming out of a barrel, HELP
  • Cameras Master
  • 5,412 Answers
Repair will be costly, replacement probably cheaper
Posted on May 09, 2017
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
INNER SCREEN NEEDS CLEANING
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
Oct 12, 2009 | Toshiba 51H84 51" Rear Projection...
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
First thing that needs to be checked is the convergence IC's. Those IC's are located in the signal board and are really hard to remove. You need an experience technician to fix it for you :)
May 27, 2009 | Toshiba 51H84 51" Rear Projection...
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Jul 09, 2007 | Toshiba 51H84 51" Rear Projection...
Picture has a green shade
Sounds like your red picture tube is not emitting enough brightness to balance the colors. A temporary solution could be to slightly increase the screen voltage of the red CRT to give a good black and white picture when the color control is turned all the way down. If the set has not been serviced in the last 5 years or so, and you're not ready for a new HDTV set, it may be worthwhile to get a technican to look at it and clean the dust off the lenses and mirror and evaluate whether a picture tube rejuvination might work along with the gray scale tracking adjustments.
Mar 10, 2007 | Toshiba 51H84 51" Rear Projection...
The TV Picture
The most common reason I've found for picture deterioration with projection TVs is dust build-up on the mirror. Try popping off the trim around the screen and look of several screw and retaining clips and remove them. Now remove the screen - it's just a piece of plastic. Now the mirror should be in plain view. Simply clean it thoroughly with windex and newspaper (you can also clean the back of the projection screen since you have it out). Now replace the screen and see if the picture doesn't look much brighter and clearer. This should be done perhaps every six months as TV generate a lot of static which attracts dust like a magnet. If the picture is blurry after doing this, it's possible to adjust the projector beams (there are three) to better align with the position of the screen, however I'm willing to bet this won't be necessary after the cleaning procedure. It sounds complicated, but trust me, anyone can do this. If you cannot locate any retaining clips on the front, you may have to go in from the back, in which case you'll most likely have to complete remove the mirror to clean it. It's a little more involved than the frontal method, but equally effective. It's also possible that you have a bad projector. When you get the screen off, make sure that each one is lit (the red one always looks dimmer than the green/blue ones). If one is out, try tapping on it, it might just come back to life, you never know. If not, have it replaced (usually around a $200 fix). Hope this helps you, and good luck!
Feb 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
Screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
