Question about Garden
I have a 0.45 thread diameter, 0.46 shank diameter 22 threads per inch bolt. Can't find. What is it? It's off a 45 year old Sensation lawn mower and I seem to remember it maybe an automotive bolt.
  • 11 Answers
SOURCE: Mower bades
I have a 2007 pollan pro 19 hp mower that i have changed the blades on and they were not reversed threads righty tighty lefty loosey
Posted on Sep 26, 2008
  • 86 Answers
SOURCE: my lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Posted on Mar 29, 2009
SOURCE: Changing blades on Huskee LT4200 Riding Lawn Mower
wd 40 is a luberecant,, blaster is a penterant ,,works much better, been using blaster sence 1960....
Posted on Apr 25, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
  • 10 Answers
SOURCE: Is the bolt holding the blade reverse threaded or conventional?
it's a 5/8" socket use air impact wrench to remove and install if you do not have these tools available take it to a reputable service station your safety could depend on it.
Posted on Apr 12, 2010
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
What size thread on a hbg10 arbor
If you can't measure it directly, take the nut with you to a hardware store and find a bolt that fits it. But you can easily measure the pitch with a decent ruler. Just count the number of threads in one inch. Count the threads from one peak to the next, So if the first peak lines up with zero on your ruler and the thirteenth peak is at one inch, this would be a 12 tpi (threads per inch) pitch. If you can measure the diameter of the threaded shaft, you will find that the actual diameter of the threaded part is just a little smaller than the nominal size. For instance, a 5/8 diameter thread might measure about 0.610 inches.
Mar 04, 2013 | Grinders
My mower stops right after I prime the engine like its not getting any fuel. I have cleaned the flywheel, gapped the armature to .013 about the size of a business card. New plug, filter ect. I took the...
Make sure all the small holes that are in the brass bolt that holds the float bowl on the carburetor are clean and clear. Use no metal objects to clean it. You should find holes in the bottom of the bolt and along the top on the non-threaded part. This bolt is also the main jet of the carburetor.
Apr 23, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
Im looking for the thread size, off the drive shaft of a power build 10.5 hp
i'm assuming your looking for the nut that holds on the flywheel? if so, measure the diameter of the thread in the crankshaft. you need the diameter and pitch(oor threads per inch) to "know" the thread size. Measure the diameter accurately. then, measure the length of the thread. example, if there is 1/2 inch of thread length and you have 4 threads in that length it is a "8" thread. so if the diameter (overall diameter measured on top of the tips of the thread) is 1/2 inch, then your thread is 1/2-8.
Jan 14, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Apr 12, 2010 | Toro Lawn Mower With Toro Power Tools
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I need to know the size and thread of a caliper bridge bolt for a 2006 883 sportster
All American threads are the same bar diameter and pitch. measure bolt diameter and count number of threads per inch, use HT steel and plated; result.
Sep 10, 2009 | 2006 Harley Davidson XL 883L Sportster
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
