Question about Boss Cell Phones
Boss bv9967b radio and other functions work but the screen is black touch screen function works but can't see display on screen
ctf1800
  • 4402 Answers
SOURCE: LCD Side Screen Display Not Displaying
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Posted on Feb 07, 2008
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
sdowney83
  • 62 Answers
SOURCE: Touch Screen not responding
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Posted on May 18, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Nov 25, 2009
SOURCE: touch screen is not working
not working touch screen
Posted on Jun 25, 2010
My boss in dash stereo model BV9967B LCD WON'T I LOMAN AT I CAN TUCH IT AND IT WORKS BUT BO PICTURE
Pull it out and make sure the illumination wire is getting system voltage when powered on. It should be the orange wire.
Jan 01, 2018 | Boss Car Audio & Video
Black screen
The touch screen has a "back light" that illuminates the screen, you will need that repaired.
Nov 01, 2016 | Cell Phones
The touch screen randomly stopped working, & isn't letting me call out/receive calls! it will force close out of pretty much everthing! I admit to dropping it a lot.. but it alwaysed worked after!, I...
hi
there must be the display gets damaged in your phone. change the touch display of your mobile screen and format the phone this will able you to fix this problem.. just change the display screen of your mobile..
thank you
Dec 20, 2010 | HTC G1
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
Only see a black screen all touch functions work just cant see whats displaying
mcdevito75 here, Monitor can be burned out, the picture portion of it. Exchage with a know good one or bring the monitor to any computer reair place, Staples, best buy and they will test it. Also double check all functions specially bright / darker on the monitor.
Jun 25, 2010 | Pioneer AVH-P4000DVD Monitor
Blackberry 9530 touch screen does not function
If the problem occurs while charging with the wall charger then try changing the wall charger.
Jun 08, 2010 | RIM BlackBerry Storm 9530 Smartphone
Display problem
try to uninstall and reinstall video card driver. Check power settings in control panel. If settings have been checked and still the same issue and working with another monitor,then might need to replace the monitor.
May 14, 2010 | Partner Tech PT-5500 PC Desktop
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Alarm clock/radio
Cut the power / batteries off and back on again to see if it will work, if not, go to www.easylifestyle.us to get a new one you need.
Jul 21, 2007 | RCA RP-3765 Clock Radio
Cell Phones Logo
73 people viewed this question
Top Boss Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Boss Cell Phone Expert? Answer questions, earn points and help others
