Question about Ovens
I think I have pressed buttons on the front of my oven by mistake and the oven is not heating up
2 Suggested Answers
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
My whirlpool oven is not heating in degrees. It is in cs. What do I do.
If you have a "Precise clean" button on top left of front panel, press and hold for 5 seconds. Release and it should display Temperature in Fahrenheit. All depends on model, of course. Hope this helps.
Oct 11, 2017 | Whirlpool Ovens
8888 display
You need to test the electrical components did this happen during a thunderstorm?
Mar 24, 2014 | Whirlpool Ovens
I have no main heat on neff oven and i think it
Make sure the oven is set for 'manual' start cooking as opposed to 'automatic'. Usually you have to press a button on the timer.
Dec 24, 2009 | Ovens
Volume on timer really quiet hotpoint forno
Pressing the "-" button on the control panel will cycle through the 3 or 4 available beep tones / volumes. No need to press any other buttons during or before this process.
Shame Hotpoint didn't see fit to put this in the manual. We dicovered it by mistake!
Jul 29, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Have whirlpool accubake oven model # RF386PXGT turned on the auto clean error code E1 F5
Self clean latch will not lock
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Dec 29, 2008 | Whirlpool RBS305PDS Electric Single Oven
Using the self cleaning for the oven
look for the door/ light switch (the door would normally have this pushed in),and press and hold it in, tricking the unit into thinking the door is actually closed. press the clean button then, see what happens. it should try to close itself entirely and then press the cancel button, it should return to normal resting position
Mar 10, 2008 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
