Question about Neff Ovens
Neff oven reset control after turning of electricity supply
Cerfer39
  • 709 Answers
SOURCE: Electrical supply
HI Zuso,
Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
Posted on Nov 23, 2007
barkencoa
  • 3463 Answers
SOURCE: The oven isn't heating up.
Hi ,and welcome to fixya.
Make sure that the timer is set to manual, and not on auto, or the oven will not work.
If it is a fan assisted oven and the fan is working, then you wiil probably find that the oven element has gone, you will find this located behind a removable cover at the rear of the oven.
It is a very straight forward job to replace same.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1421 double oven fan has packed up ?
Yes it is the fan that needs replacing.
It is a fairly straight forward repair, just remember that the nut that holds the fan blade on is a left hand thread, so to undo it, turn
it clockwise, as though you were you were tightening it.
Please leave a fixya rating for my solution.
Thankyou.
Posted on Feb 04, 2009
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
  • 228 Answers
SOURCE: oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
Posted on Jul 20, 2009
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
Nov 23, 2013 | Neff B1421 Electric Single Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
My outer glass on door has shatter by its self can it be replace
You should be able to obtain a replacement door glas, they are usually supplied as a seperate item.
Try the following.
WWW.ESPARES.CO.UK/NEFF
WWW.NEFF.CO.UK/CONTACT.HTML
Mar 07, 2010 | Neff B1421 Electric Single Oven
Hi
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Feb 27, 2009 | Neff B1641 Single circotherm super...
Thankyou.
Feb 03, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
