Question about LG KC910 Renoir Cell Phone
Sound Problem All the tones seem to have vanished, when I'm in a call my friends can hear me but I can't hear them. checked settings and profiles all seem fine. tried using head set and only makes things worse, I can't hear anything at all with headphones. Phone is less than 6 months old.
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Got no sound coming out of my speaker and can't hear anyone when they phone me
hi..
  • Check that the volume in the application is turned up and that your phone is not in "Silent" mode. You can control the volume by pressing up or down on your phone.
  • For Nokia devices, you must have the Warning Tones enabled in your phone's settings to hear audio . This setting can be found in "Profiles" > "Current Profile" > "Personalize" > "Warning Tones".
  • The above issues is not useful means definetly you have to change the speaker...
Jan 03, 2011 | Cell Phones
Hi how can i increase volume on my blackberry 9000. Even on high volume setting there is no ringtone sometimes
Hi there
On your Blackberry menu, there's an icon that resembles a person's head that represents profiles. In the profiles menu, you can select the volume for the notifications you receive when messages or calls come in. Choose "Loud" to hear all notifications at an equal volume, equivalent to the maximum output possible.
Some ring tones just remain less audible than others even when they're set to maximum volume. If you've tried increasing the volume of your notifications but still can't hear the ringer sometimes, try downloading a custom ringtone from the Blackberry App Store.
When selecting a custom ringtone, choose something distinctive and hard to ignore. When previewing the tone, determine whether it seems louder or easier to hear than your existing tone. Download more than one tone and experiment throughout the day.
After you've downloaded custom ringtones, set your phone to use these ringers by going into the applicable notification profile. Select "Show Tunes" and open the media folder where you've chosen to save your downloaded tones. Select the ringer you want and click "Set as Phone Tune."
Oct 04, 2010 | RIM BlackBerry Bold 9000 Smartphone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
No sound Blackberry
Check your profile settings and make sure that it is not set to phone only or all alerts off. If it is set correctly double check your ringtones and make sure they are set for sound. If those options are there then do a battery pull. If it still doesn't work then I would do a search on the crackberry.com website. It is a great site for all things blackberry.
Apr 29, 2010 | RIM BlackBerry Curve 8310 Smartphone
Normally if i get a message on the screen says message received and there was a tone but now, the message symbol is small at the top right hand side and no tone can be heard but i could hear the tone when...
Dear Friend jut check the settings in text message whether the message alert tone is still active or not.
Also chek the profile on which phone is active on,there may be an option in the phone which says the message tone settings.
And also check the tone settings on the mobile
Thank You
Apr 22, 2010 | Nokia N72 Cellular Phone
Turn off key pad tone
In the main screen, press the volume button on the side. It will open up the volume control on the screen. Set it to zero and thats it. It will turn off the keypad tone.
Sep 23, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Lg renoir phone - sound issue
You are in the right place but looking at the wrong option, if you scroll down on the Normal profile you will see a message tone option, if you are not hearing a tone at the moment then I suspect it will say "No Sound". Tab this option and select Existing sound, you will then be able to navigate through the sound files on your phone and choose one of the Default Sounds (from the folder by the same name) or an MP3 or other supported sound file you have added to your phone.
If that doesn't solve your problem then you may have a faulty phone.
You can change the sound you get when sound alert is switched on by going to Settings > Touch Settings > Touchscreen Effect and choosing a different sound from the Tone option. You can also change the volume of the tone of severity of touch vibration here.
Jul 27, 2009 | LG KC910 Renoir Cell Phone
Volume of my phone isn't loud as it was earlier inspite of full
It could be a hardware fault or profile settings.
If you check your profile settings, by going to profile, scroll to the bottom of the submenu and select advanced.
In the next menu - select your active profile and the edit option
Then select one of the features such as phone, you would previously have associated with loud tone and check both out of and in holster settings for volume.
May 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
NO RINGING TONE
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
Jul 18, 2008 | RIM BlackBerry Pearl Smartphone
LG KC910 Renoir Cell Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
