Control panel for semi auto machine model we -8003
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
I have a Faema Due espresso machine and I need to know about the correct use of the red cup symbols over the heads. Can you help please.
Faema Due depending on the model semi or auto has either 6 buttons for auto and any where from 1 to 2 for semi. There are 2 short level cups single and double and 2 long level cups. They are for ristretto or restricted and lungo or long, but if you only use 2 ounce or 3 ounce shots depending on your preference. I usually set all buttons to shop preference because in the US most shops either do 2oz or 3oz espresso shots. The cup with the dots above it is continuous run and ofcourse the stop is... On the semi you have one cup and stop or a push button.
Mar 23, 2013 | Faema Coffee Makers & Espresso Machines
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My washing machine model 8204 semi-auto is having problem of water leakage through the drainage at very low pace taking 2-4 hrs . what to do? plz suggest.
You need to raise the drain pipe up about 250mm to stop the water siphoning out. When it is high, the flow will stop untill the pump tells it to come out.
Sep 01, 2010 | Samsung Washing Machines
Safety valve cn10 keeps activating about 10 seconds after switch on. any ideas anyone. stafco markus 2 group semi auto
Try this open the steam wand and leave on when turning the machine on, when valve stats hissing with steam close. If that works then the vent valve needs to be replaced, If it blows out hot steam from valve then the pressure stat is not operating properly.
Jun 22, 2010 | EXPOBAR Office Control Espresso Machine
Continuous beeping after turning machine on (model M21 old)
I don't know if you have the semi or auto model so check the level and inlet solenoid, it is possible machine cannot put water in the boiler. Then check the thermostat on the boiler and the element.
Jan 26, 2010 | Espresso RMI La Cimbali Espresso Machine
Water is not draining out
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Feb 18, 2009 | LG WM2487H Front Load Washer
Can I remotely control speaker outputs on the Marantz PM 8003?
You need an 8 ohm stereo "L-pad"
Dec 21, 2008 | Marantz Audio Players & Recorders
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
