Question about Sewing Machines
We have a Newlong HR4A carpet overlocker.Should the valve nibs on top of the two auto oilers be Up or Down when the machine is in use? Also how can I adjust the stitch density? Thankyou
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: Kenmore sewing machine - uneven top stitches
Am about to buy this machine for my wife and the sewing machine cabinet I have chosen has parameters as far as the overall dimensions of the machine. Can you provide me with the width, depth and height of this sewing machine. The cabinet is offered for sale by Sears so it ought to work but still I will feel better with this information. Thank you.
Posted on Feb 05, 2008
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
  • 323 Answers
SOURCE: unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Posted on Jul 18, 2008
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Can I do a double cover stitch on a Semco 750D overlocker
Semco 750d Overlocker Manual ' downloadfreefileshere.com
downloadfreefileshere.com/manuals/semco-750d-overlocker-manual.html
Dec 11, 2014 - Semco 750d Overlocker Manual Yahoo Messenger was the only program that Update Notifier caught. Few options per tab keep down the ...
Jul 28, 2015 | Sewing Machines
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
Why does fabric get caugh on the roll hem devise when over locking
this sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
May 13, 2014 | Elna Sewing Machines
M546 brother overlocker
it's possible that when the left needle broke, it could have caused a missalignment in the machine, it would be a good idea to have the machine checked.
Nov 09, 2013 | Brother Sewing Machines
Operating manual for Singer Sewing Machine 132K6
- Go to: http://www.matparts.com/manuals.php
- Scroll down to the Newlong DD-5
- Download instructions/"View Manual"
- This is supposed to be the same (made in Japan) machine as the Singer 132K6
Aug 11, 2012 | Singer Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
