Question about Saws
I have a Delta Miter saw model 34-079. The belt broke so I ordered 2 new belts. I tried to install one and it was so tight that it tore the new belt. Is there some adjustment to tension the belt?
  • 674 Answers
SOURCE: Fan Belt wont fit on my saab 900
Posted on Aug 24, 2008
  • 1996 Answers
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking:
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
SOURCE: Serpentine belt too tight to install
I had the same problem when trying to replace the serpentine belt on my 2001 Trooper. The Maintenance book was very vague and I couldn't tell exactly how the tension was taken off the belt, but it did clearly identify the tensioner pulley. I first removed the pulley and looked for some kind of slot that would give me the adjustment I needed, but no slotted adjustment is present on the 01 Trooper. I had to do some research so I pulled of the tensioner assembly and found that there is a spring coil which keeps tension on the belt constant, and eliminates any belt alignment problems.
The Litens style tensioner uses a spring to apply pressure towards the serpentine belt. The way to relax the spring is to use your 14mm socket and ratchet and force the pulley down by driving the pulley nut in the clockwise direction. This forces the spring to compress and the pulley to drop giving the needed clearance to get your new belt in place.
Posted on May 09, 2009
  • 272 Answers
SOURCE: New Hoover belt nbr 385280-34 installed, belt still too loose.
There is no adjustment. As they wear they cut the groove in the roller deeper. Sure fix,and what Hoover will tell you to do is to replace the roller. If your like me though that isn't any good. so what I did was wind wax coated dental floss into the groove that the belt rides in and in and then put a couple of drops of super glue to hold the end and it works like a charm. Don't put too much in there the belt has to have a groove to ride in.
Posted on May 25, 2009
SOURCE: 2005 Nissan Sentra 1.8S, with AC - how to replace belts?
first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
Posted on Aug 23, 2009
How to install;drive belt on model 34-670 saw ?
You must lower the motor down as far as possible and then tilt the saw blade so the back end of the motor where the belt is housed is exposed and accessible as possible. Then remove the cover housing at the back end of the motor. This will expose the belt. Thenyou can remove the old belt and install the new one.
May 19, 2014 | Saws
The belt on my new saw started to frey after some use
It sounds like you need to replace the belt. try the following websites, they offer the saw parts:
Feb 10, 2013 | Bosch 5312
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
I need a drive belt for a Delta bs100 band saw
Visit Search on your model number, they have a breakdown of your saw. You can order the belt from them or use to part number to search the internet to see if they are available elsewhere.
Feb 11, 2011 | Delta BS100 Shopmaster 9 Inch Bench Top...
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
Manual for Delta 10" compound miter saw 36-220
The Instruction Manual for the Delta 10" 36-220 Miter Saw can be downloaded from the following site:
Note that there are three models of this saw. The model numb r on your saw will be followed by -1, -2 or -3.
Select the model number you have from the on-screen drop down box. When the page refreshes download your manual by clicking the icon under PRINT DOC.
Sorry someone has not responded sooner.
Sep 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Saws Logo
61 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
