Question about The Audio Players & Recorders
Volume control. Maximum is at 4. What is the problem?
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: no volume sound very low at maximum
Look both at the set and the Box if used (cable or sat) to make sure volume is not turned down---also a receiver if used can do the same thing.
A quick low tech test is do you have the same problem when playing a DVD etc.
Posted on Apr 25, 2012
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
Music wont turn up -- too soft to hear properly
It could be that the maximum volume limit has been switched on too low.
Go to settings then playback and then volume limit, the volume control shows the maximum volume it has been set to. Use the click wheel to select your maximum volume and then press the centre button to set the limit. Then choose done. Hope this helps.
Dec 10, 2011 | Apple iPod nano
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
Sep 10, 2011 | Dell Latitude E5500 Laptop
What is the ohm value of the input volume controls on this amp?
For the Tascam DP-01 Digital 8-Track Portastudio, here are some of the specs:
  • Analog specifications
  • Inputs (A And B) 1/4" Phone (Unbalanced)
  • Input Impedance: > 10k Ohms (Max), Or 1 M Ohms (A Only) With Switch In
  • Guitar Position: 2.4 K Ohms
  • Nominal Input Level: -10 Dbv -
  • Maximum Input Level: +6 Dbv
    Effect Return 2 X 1/4" Phone (Unbalanced)
  • Input Impedance: 10 K Ohms
    Stereo Mix 2 X 1/4" Phone (Unbalanced)
Courtesy of Musicians Friend
Mar 27, 2011 | Tascam Audio Players & Recorders
How do you turn the volume down
1. Turn on the cube2. Hold silver + yellow at the same time while the startup music plays3. At the end of the music the voice will say "volume control, volume level ..."4. Release the buttons5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4".6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
Dec 26, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
The volume on my acer aspire 5532 is not very at maximum level
Go to Device Manager and up date your drivers if this don't fix the issue. Try removing the driver and visit http://www.acer.com/worldwide/selection.html select your location.
Visit the drivers download section and download a fresh driver.
Dec 26, 2009 | Acer Computers & Internet
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jul 15, 2009 | Apple iPod classic MP3 Player
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
