Question about LG Heating & Cooling
Code CH04 & CH05 Lg casset type unit - LG Heating & Cooling
3 Suggested Answers
heinzhvac
  • 229 Answers
SOURCE: Our LG wall aircondition displays
This means your float switch for the drain pan has tripped you probably have a clogged drain.
Posted on Jun 24, 2011
kevin_getz
  • 1031 Answers
SOURCE: how to fix lg with code CH05
Fault Code 05
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
Posted on May 09, 2012
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Fault Code 05
May 08, 2012 | LG Heating & Cooling
What is the cause of ch05
if it is lg the outdoor pc board.
Nov 08, 2011 | Heating & Cooling
Displays CH04 error
Hello
THis is a heatsink Temp sensor open circut error.Try cycling power on and off to unit.If this does not work you will need sevice as this part is part of the control board.
Sep 17, 2011 | LG LSC121PMA Split System Air Conditioner
Our LG wall aircondition displays a CH04 code. Can you tell what this is, please?
Jun 24, 2011 | Heating & Cooling
Heating & Cooling Logo
135 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
