Question about Ryobi Garden
Ryobi RM-2000 Lawnmower brake not releasing properly. After removing cutting blade, how do I remove plastic fan underneath it?
4x4papa
  • 14 Answers
SOURCE: riding lawnmower blade
First, always wear safety glasses and hand protection when working on machinery. Also include my favorite saying; "Common Sense Prevails". No amount of overgrown lawn is worth getting hurt. Work on as flat a surface as possible, always chock the tires in both directions to prevent movement and disconnect the negative battery cable making sure it will not contact either battery posts while working on the mower. This will insure the engine will not start on it's own or the mower move of it's own accord. Release the parking brake, with the shifter in "neutral" position. Check your tire chocks and make sure the mower is not going to roll in either direction. Now, lower the deck to it's lowest position. Now loosen any guide pins that extend from the underside of the main chassis that keep the belt from coming off the drive pulley on the engine. Again, there may be one or more. Remove the belt from the pulley. Now find the linkage that tightens the belt when you engage the blades. It should extend from the chassis at an angle to the deck. If your mower is equipped with a PTO (power take off) clutch that engages the blades by a switch on the dash, skip this step. Now remove the clips that secure the raising\lowering arms from the linkage at the top of the arms, not the deck end. This will allow you to slide the deck, slowly and carefully out from under the mower, with out the arms "dangling" from the mower interfering with the deck. You will have to adjust the angle of removal as you are sliding the deck as most have an "attack angle" that is not 90 degrees from the strait line of the mower from front to back, but is angled more forward on one side or the other. Once the deck is clear of the mower, depending on the size and weight you can lift it (with help) or use a floor jack to raise it (being VARY careful not to contact the blades) and lower it onto 4 blocks at least 4 inches high. Place the blocks at the 4 "corners" of the deck. Two blocks long enough to run past the length (front to back) on both sides of the deck will work as well. Remove the covers on both sides of the deck that cover the belt\pulleys on top of the deck by removing the bolts that secure them. Most are a self tapping type, some have nuts and washer on the underside, and some have studs welded to the deck, so you don't have to reach underneath. Some tractors have one of these covers, some two, and some non at all. Clean the top side of the deck with high pressure water from a garden hose, or a pressure washer if you have one. Be careful of flying debris. There may be rocks, pebbles or other items that can become flying missiles and injure you, or someone close by.Flip the deck over, again being careful not to trap your (or your volunteer's) hand between any moving parts and the deck (like between the sharp side of a blade and the deck housing) and place on your blocks in the same position. You can now access both the nuts holding the blades and the top side  of the pulleys that either have nuts as well, or are made to accept a wrench or socket. Using a block of wood, ("2 x 4" x 12" is a good size but adjust the size to fit your particular deck) insert the block between the deck and one blade on the side of the blade that will stop it when loosening the nut holding the blade, making sure to get a good "bite" so it will not slip when pressure is applied. You can also use a wrench or socket on the pulley retaining nut on the top of the deck to stop the blade from moving as they both employ the same shaft. A volunteer to hold this is a good idea, perhaps a must. Make sure to equip them with safety gear as well. Apply a good lubricant like PB Blaster to the retaining nuts on the blades. Allow at least 15 minutes to absorb. Using either a 3/8" air gun or ratchet, or if using hand tools, a 1/2" breaker bar with the proper size socket of an impact grade, loosen the nut holding the blade. Your volunteer can help by hold the deck as you apply pressure to the bar. An extension of the breaker bar's handle with a piece of steel pipe having an inside diameter not much bigger than your breaker bar, and no more than a couple feet in length can be applied for more leverage, however this should only be done by someone with experience using the technique. Better to use air tools or a proper extension than bust up your hand by a slipping ad hock device. Remove the nut and washers, keeping them in the proper order for re-installation, and remove the blades noting which side is up and down. The cutting edge of the blade is always the lowest part of the blade when attached. Clean the underside of the deck. You may have to include a scraping tool as grass buildup can become quite hard over time and appear to be part of the deck. Pay special attention to moldy, wet grass around the blade shaft. This kind of moisture can induce corrosion prematurely to the deck housing and the bearings\shaft housing. Look closely for any type of wire, line from weed eaters, cables or any line that can be picked up by the mower and can wrap around the blade shaft between the blade and the deck. This line can eventually work it's way into the bearings, causing the bearings to fail.  Carefully inspect the shaft, bearing and it's housing for damage, corrosion, etc. Repair\replace as needed. Remove any surface rust with a wire brush (hand or power) again watching for flying debris. Inspect the blades, looking for obvious impacts that have caused visible damage to the blades. If found, remove the blade shafts and check to be sure they haven't been bent. If they have, don't try to straiten them, but replace them. A bent shaft will have caused undue wear on the bearings, and a straitened shaft will be weak where the bend was. A failure of the shaft, bearings, or bearing housings can be fatal if the blade becomes detached and manages to fly out from under the mower while in use and strikes someone nearby. Now sharpen the blades, or replace them if needed. An experience blade sharpening service should be employed as the angle of the cutting edge and the level plane on which they travel is critical. Simply using a grinding wheel will not give you anything but a sharp piece of steel, but will cut unevenly. Clean any buildup from the blades and the shaft's mounting platform for the blades as rust or any foreign substance will cause the blades to be at an improper angle. While the deck is removed, inspect the holes where the raising\engaging linkages attach looking for wear to the hole or the linkage shaft. Replace if any undo wear is detected. Check for side to side movement of the pulley\blade shafts indicating a worn shaft or bearing. Replace if needed. Check the bearing housing the shaft travels through on the deck for electrolysis corrosion cause by dissimilar metals in a moist environment), cracks or other damage. Replace as needed. Inspect the deck belt for wear, cracking or age and replace if needed. It's always a good idea to replace it regardless when performing this deck//blade service. Reassemble in the reverse order of dis-assembly, using Loctite red on all threaded surfaces, and greasing any available grease fittings. Apply a coating of graphite lube or grease to the linkages where the attach to the deck an mower. Make sure all fasteners are tighten to proper specs. Lift the deck to it's highest setting, engage the parking brake, and reattach the battery. Start the mower and engage the blades checking for any undo noise indicating loose parts. Check the deck movement by lowering to different settings always listening and feeling for vibrations or noises. Should everything be in order, you may consider leveling the deck for optimum cutting performance. But that's a different question........ Best of luck, and please indicate your rating of this solution if appropriate. Thanks so much, Papa
Posted on Nov 18, 2008
SOURCE: ryobi lawn hornet wont start....continually
Hi Tamcoff - If its the same model as mine (and you can't always rely on the Parts Cattledog!!):
- to remove the bell housing; twist off the spring and using a T20 torx screwdriver unscrew the retaining screw in the centre of the housing (normal RH thread)
- place a large screwdriver in the slots of the cover to jam the impeller and using a copper drift (or similar) and hammer, tap sharply the in one of the clutch recesses (one of mine hasd 'OUT' embossed in it) unscrew the clutch from the drive shaft (normal RH thread)
Cheers,
Bob
Posted on Dec 08, 2008
jj505
  • 195 Answers
SOURCE: replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Posted on Mar 28, 2009
SOURCE: Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Posted on Mar 31, 2009
emissionwiz
  • 78267 Answers
SOURCE: how to release fuel pumps pressure properly before servicing
do it at the schrader valve pressure test port on the engine, the valve is located in the fuel supply rail to the injectors, looks like a tire valve.
Posted on Apr 28, 2009
Lawnmower dies when I put it in gear, why
Sounds like a safety switch somewhere.. Check the seat switch first, that is what happened to mine. Does it smoke the belt and stop? or just cuts off when you release the brake? If when letting out on brake, pretty sure it is the seat safety.
Oct 07, 2014 | Garden
Briggs & stratton pull start problems After
remove the spark plug and see if it turns over. If not you will have to see why it is not turning. Check underneath for something caught around the blades and shaft.. Check oil level and if no oil it may be seized
Sep 08, 2013 | Measuring Tools & Sensors
I friend has a craftman riding lawnmower with a problem, when the brake pedal is push down the engine will run, but when you released the brake pedal the engine wants to shut down, also when you pull the...
The drive pulley underneath has an arm with a rubber brake that rubs against the pulley when the brake pedal is released. Make sure that it is not jamming or defective.Let me know if this helps
Jan 19, 2011 | Craftsman Garden
Light comes on but fan does not. Electrician just here and it is fan not switch
mcdevito75 here, If the fan is brand new and just installed, you may have forgotton to remove the brakes off the fan motor while installing the fan blades to the fan motor, these brakes are pieces of plastic to keep the fan motor from turning in the box while shipping from the factory, remove 1 fan blade and either on top or just underneath the fan motor where the blades screw on are small pieces of p[lastic that will keep the fan motor from working, simply remove these plastic brakes.
Jul 06, 2010 | Craftmade International Craftmade Omni in...
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to adjust....et voila....
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
When i try to engage my blades on my lawnmower the belt starts smoking and the mower will cut off
You either have something wrapped around or jammed in your blades(obstruction of some sort), or the bearings seized in one of the blade shafts. Check underneath and see if there's something stuck or wrapped up in there, and remove it if present. If not, turn the individual blade shafts to see which one is stuck, and that's the one you'll have to replace.
Mar 21, 2010 | Garden
I HAVE A RYOBI LAWNMOWER WHICH SEEMS TO CUT WITH LINE,NOT A BLADE.IS THIS POSSIBLE?ELABORATE
If it is a curved shaft it will be a flex cable drive therefore it will break if you run a blade as it puts too much pressure on it.
Jul 23, 2009 | Garden
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Garden Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
