Question about Galaxy Cell Phones
My Galaxy s6 is totally black and won't come on I have tried everything and nothing no power at all I didn't drop it or get it wet it was working just fine
It went dead I put it on the charger when it said 42% I went to turn it back on and that's when it went black
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
SOURCE: PSP no power
Ms Piggy....
It sounds like your PSP is "bricked". Have you upgraded the firmware or added custom firmware? If so, you'll need a Pandoras battery/memory card to repair. Try ebay for those.
Good luck
Posted on Apr 02, 2008
SOURCE: kawasaki zzr400 (1994 model),streetfighter wont start
Its Starter relay may be causing main problem. You can try Yezdis starter relay as it can help you solving your problem
Posted on Jan 23, 2009
  • 66 Answers
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Posted on Feb 16, 2009
  • 414 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
Having trouble pressing on glass to open some tabs
Search Results
    Why won't my tablet's screen respond to touch? - Samsung ...
    https://www.ifixit.com/.../Why+won't+my+tablet's+screen+respond+...
    iFixitThe third generation of the Samsung Galaxy tablet with a 7-in. screen ... The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes ... the volume up and down at the same time and pressing the power button. ... if you havetried all of these solutions then your device should start working again.
    6 problems with the Samsung Galaxy S6 / S6 Edge and how ...
    www.androidauthority.com/samsung-galaxy-s6-s6-edge-problems-fixes-...
    Jul 3, 2015 - Disclaimer: Not every Samsung Galaxy S6 and Galaxy S6 Edge owner will face ... Lastly, some users have reported that on unlocking the device using the finger .... apps ... on s5 it was possible to open menu button with long press of left "button" . .... Bought last week a Samsung Galaxy Tab S 8.4 which is an
    Samsung Galaxy Tab S2 8.0 Glass Screen Protector
Dec 17, 2015 | Samsung 32GB Galaxy Tab Pro 12.2" Tablet...
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
Dec 14, 2015 | Samsung Galaxy S6 Edge
Galaxy S6 wifi issue
First, try restarting the Galaxy S6. To do that, hold the power button on the right side of the phone until prompted. Hold it down again to turn the Galaxy S6 back on. It's a simple process but it has been known to dislodge Wi-Fi issues
If that doesn't work, Galaxy S6 users will want to try rebooting the local router if that hasn't been done in awhile. We recommend unplugging the router for a good 30 seconds and then plugging it back in. Users can do the same for the modem as well. Galaxy S6 users might also consider updating the routers firmware. This process will be different depending on make and model. If those simple fixes don't work, it's time to head into the Galaxy S6's settings.
If the Galaxy S6 isn't getting a solid connection, it's time to force the device to forget the Wi-Fi network in question. To do that, head to the desired connection in Settings. On the Galaxy S6, this can be found in the Connections portion of Settings. Once there, select Wi-Fi. Tap on the desired network and select the Forgetoption. Users will then need to reconnect to the Wi-Fi network. Make sure the password is readily available or the device will be locked out.
If that doesn't work, head into Wi-Fi, tap More in the top right corner, and select Advanced. Ensure thatAlways allow scanning is turned on. You'll also want to make sure that Keep Wi-Fi on during sleep is set toAlways.
Jun 09, 2015 | Samsung Galaxy S6 SM-G920F 32GB FACTORY...
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
How to reset huawei phone
Recover Photos from Pattern Locked Galaxy S/Note/Tab
"I've set the lock screen password on my Galaxy S6, but I forgot it later. There are a lot of important photos saved in my device. What what I should do to gain the lost pictures on a locked Galaxy S6? Will i lose my data?"
With the screen locked, one will have no way to reach your personal information, including images. If you lose out on your phone images, you might lose out on all those precious memories. Luckily, it is still possible for you to bypass the locked screen and recover photos from pattern locked Samsung Galaxy S/Note/Tab with Samsung Data Recovery.
Samsung data recovery program which is a professional Android data recovery program is capable ofrecovering deleted and lost photos from a locked Galaxy S/Note/Tab, the same as videos, contacts, text messages, call logs, audio files, documents and more. This program helps you in:
Recovering inacessible, lost or formatted data from locked Galaxy S/Note/Tab's internal as well external memory.
Retrieving data including images, contacts, SMS, documents, videos, whatsapp messages and more.
Recovering data from broken Samsung Galaxy, like broken screen, black screen, etc.
Feb 06, 2014 | Cell Phones
Nikon s6 coolpix
I would check with Nikon and see if it's covered under warranty still. There could be something going on with the CCD unit
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Cell Phones Logo
Top Galaxy Cell Phones Experts
dhnguyen
Matthew Spark
Matthew Spark
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
