Pc shuts down ,reason cpu overheating
My pc shuts down within 10 min of starting it.When i restart,i get a
message that cpu was shut down due to a thermal event.In case of games this shut down is instantaneous.
I opened up my pc to see whats wrong. I found out that the intake fan
wasn't rotating fast. I replaced it with my friends old one .the power
ratings were a bit different though ,the old one had a rating of DC
12v max .13A,the new one has a rating of DC 12v max 0.20A.The fan is
working properly.The problem still persists.I have even removed side
panels and am providing external cooling through a table fan.I also
cleaned my pc.
One more thing within 2 min of windows starting the pc slows down.its
like the pc hangs every 2 seconds for a second.After 5 min the pc goes off.
I got a core2duo 1.8 ghz. 1.5gb ram, 8800 gt graphics card.My motherboard is,Intel D946GZis
plz help !
thanks for your time :)
shreyas
    President:
  • 3,278 Answers
Since you have cleaned the inside thoroughly, could be a capacitor problem - replace capacitors.
It's also possible that there is a bad thermal contact between the NorthBridge chip and it's heatsink. That's the chip/heatsink combo immediately below the processor. Just remove the spring clip that holds the heatsink in place. Use a toothbrush and a good solvent such as denatured alcohol to remove the thermal pad and associated heatsink compound from the heatsink. Then remove all residual heatsink compound from the chip itself. Once everything is very clean, apply a VERY THIN coat of new heatsink compound to the top of the chip AND the bottom area of the heatsink where it comes into contact with the chip.
If this doesn't do the trick, you probably have a bad motherboard.
Posted on Jul 25, 2009
  • 112 Answers
You need to remove the fan and cpu heat sink, and clean and reapply heat sink compound. Put a thin layer on cpu then install heat sink and lightly push down and give it a little twisting motion to spread compound, install fan then clip down or clip then put fan on what ever your system requires.
Thanks for using fixya!
    President:
  • 828 Answers
Have your ever changed your Power Supply, if not then try to change or test any Power Supply available, why! Because it might be due to low power of your power supply, sometimes its does do that. Then you say all are being check, right! Your Motherboard, Fan is OK. And last thing is remove some devices that are still connected or any removable device on it. Good luck!
  • 736 Answers
A far more important fan is the one on the CPU itself ..
the differences between the specs on the fan you replaced and the original is insignificant .. that should be fine for a cabnet fan
several things can cause a thermal event ..
1. if the cooling fins on the CPU are clogged or its fan is not working
2. if the heat sink grease is missing or not used properly on the interface between the CPU and its heat sink ..or the heat sink is not mounted properly
since your system is shutting down so quickly i would suspect the second case above ... i would remove the heat sink from the CPU then clean both surfaces and reapply a recommended heat sink interface material ... i use a silver bearing grease .. careful not to use too much .. remount the heat sink and make sure its not being held up (or interfered with) by some other component ..make sure its square and in good contact against the CPU (not cocked) .. make sure the spring that holds the heat sink in place is latched at both ends ..
    President:
  • 1,257 Answers
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
In the bios Disable "CPU Fan Control" and "System Fan Control". I had the same problem with the D946ZIS motherboard. When those 2 features are enabled the fans slow down after startup and the CPU overheats forcing the the computer to shutdown. Once I changed both those settings to disable it never shutdown again because the fans operate at full speed.
Posted on Oct 30, 2012
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
CF-29, shuts down periodically. restarts then works for a while, then shuts down. Error message says something about a mini dump.
Maybe due to overheating issues. Clean up the cpu FAN (HAS TO BE FREE OF LINT AND DUST). For this you have to disassembly your laptop
If that doesn't help you may want to run Windows Recovery Console
Nov 16, 2010 | Panasonic Toughbook 29 Touch (P/N...
It does not stay running more than 10 mins then shuts off, when you restart it almost immediately shuts off. The computer is almost new
The symptoms you are describing sound like it could be a cooling issue on the CPU, if the hit sink is not secure the processor could be overheating causing the PC to shut down.
Its not definaitive answer I know, but you should check its secure and has good contact.
Mar 04, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Laptop keeps shutting down
Check the key hybernation
Start >> Control Panel >> Power Options >> Hybernate (must be UNCHECKED)
See another features.
Check your bios at CPU to check if overheating feature is activated,
check the temperature of your CPU
Oct 29, 2008 | NEC Versa Premium Notebook
Dryer shuts off
motor overheating ..doesit "groan" when start button pressed ? If so bad motor ..possible excess lint due to poor exhaust system caused lint build up around motor causing overheating and motor damage .new motor only fix
May 02, 2008 | Kenmore 62602 Electric Dryer
PC gets shut down
this means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, newegg.com is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Jan 06, 2008 | Audio Players & Recorders
Computers & Internet Logo
483 people viewed this question
David Payne
David Payne
