Question about Nordic Track Exercise & Fitness
Nordic track T9 SI - FF error on display? - Nordic Track Exercise & Fitness
SOURCE: operating manual for cx1050 nordic track ellpitical
http://www.iconservice.com/pdf/NEL12940.pdf
I just downloaded a copy. It's 32 pages.
Posted on Feb 19, 2009
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 95 Answers
SOURCE: Nordic track c2255 console displays FF and will
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Posted on Aug 01, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
Running platform slipping on my T9 treadmill
see the videos attached. lube the rollers bearing front+back
God bless you
Oct 16, 2013 | Nordic Track NordicTrack - T9 Si Folding...
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
In demo mode wont start regular program.
12_12_2011_7_03_17_pm.gifadjust by 1/8" ,tight the flexible cable form keypanel vs display board , then display board vis main motor board(lower board). Exchange batteries new from console.
Dec 12, 2011 | Nordic Track NordicTrack T7 si Treadmill
Need manual for nordic tract x7i
go to www.nordictrack.com then to customer service, then parts & manuals give your model, etc, and download for free.
sincerely
G-d bless you
ERNESTO CUADDRA
MANAGUA,NICARAGUA. C.A
Dec 08, 2011 | Nordic Track NordicTrack T7 si Treadmill
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
Looking to down load user manual for nordic track t7si
The manuals are available at
http://www.iconservice.com/CustomerService/manuals.do
Be sure to have the actual model number (NTTL..., NCTL...) to be sure to find the correct manual.
Mar 01, 2011 | Nordic Track NordicTrack T7 si Treadmill
Treadmill display screen is clear. treadmill still runs, just screen does not show up
What your seeing is a common problem which I encountered on 3 separate displays. I have since diagnosed the problem and am currently life-testing a working solution.
The real problem is very poor design of the negative voltage generator circuit for the display contrast. Everything else is working fine except that circuit. I have designed and installed in my treadmill a replacement circuit that is much stronger and am currently testing it.
zubatcha@gmail.com for more information
Jan 15, 2011 | Nordic Track NordicTrack T9 ci Treadmill
Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
Apparently Sears will be replacing our treadmill at some point!
Mike
Jan 10, 2011 | Nordic Track NordicTrack T7 si Treadmill
Nordic track c2255 console displays FF and will not do anything
Jul 25, 2009 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
37 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
