Tried to sync replacement jawbone UP3 to i phone. Not working.
Have removed old UP app and reinstalled, turned Bluetooth off an on again to try and sync to no avail. New band fully charged
Cpyles07
  • 56 Answers
SOURCE: Motorola H700 wont sync with my Palm Treo phone?
Did the headset become unpaired with he phone? If so make sure the boom is closed and Hold down the button on the side until it starts to blink then run the wizard
Posted on Dec 06, 2007
SOURCE: Bluetooth
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
Posted on Sep 27, 2008
SOURCE: Bluetooth pairing problem
if your phone does not pair with your jawbone then you might want check you phone's bluetooth visibility which can stop your phone from syncing even if your bluetooth is turned on. You can find it in bluetooth setting
Posted on Mar 17, 2009
joe7379
  • 93 Answers
SOURCE: can't pair new phone to bluetooth
try 4444
Posted on May 20, 2009
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
Is the bluetooth on Capella sleep and sound alarm clock, CR50, compatible with an Android samsung galaxy s4? I can't get it to pair
Samsung Galaxy S4: Trying to pair by Bluetooth to Capella CR50 Desk clock: Unable to pair:
Hello..
Yes, the Capella CR50 should be able to Bluetooth pair with any device that can connect via Bluetooth (as stated in the Capella product description).
If you are not able to connect try doing the following (process of elimination) to resolve why this is happening:
  • Turn off and turn on again Bluetooth mode
  • Try resetting the Bluetooth app in Applications>All Applications under Phone Settings
  • Try eliminating apps that may be affecting the bluetooth connection.. you can narrow this down by rebooting the phone into Safe Mode. If in Safe Mode, your S4 is able to connect via bluetooth to the Capella CR50, that will tell you that it is software related, and most likely an app that you installed that is not playing nice with your phone. You can either remove apps one by one and retrying to connect via bluetooth to find and eliminate the issue, or remove all the apps you installed and start fresh.
(Note: removing an app with erase any settings you set up as well as any database within the app (such as a game with scores/levels/and any rewards you received/purchased, unless that database is saved in an online cloud account you sign into specifically for that app, or sync to Facebook (FB) while having the game installed in your FB account
How to get S4 in and out of Safemode:
How To Set Up Bluetooth On Your Samsung Galaxy S4 Phones 4u
Jan 29, 2016 | Samsung Cell Phones
Blue tooth cuts in and out, jawbone.
I am having this SAME problem with MY Commando.
Exchanged the Jawbone with a new one of the smae model. Same thing!
Have even purchased a BOSE Bluetooth to replace the Jawbone that I still own, EXACT same condition with both ( all THREE units if you count BOTH Jawbones ).
Anybody have any suggestions? I love the phone otherwise, but cannot use a Bloothheadset! VERY ANNOYING !
Any guruh's ( I am not )have a solution?
Much appreciated!
Oct 02, 2012 | Casio G-zone Commando
How do you sync a motorola droid with a jawbone
Have you tried shutting the Jawbone off, hitting scan for devices on the Droid, then holding the connectbutton(long thin black button) on the back at the same time time you turn the Jawbone on(Black and blue sliding switch)? This is the only way mine will find and connect to my Jawbone!
Mar 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My Jawbone bluetooth wont go into discovery mode.
I believe it needs to be on....then hold in the button for pairing until it is steady red....once it syncs up it will start flashing white until you turn it off.
Oct 22, 2009 | Cell Phones
Mar 17, 2009 | Cell Phones
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
I cant scan phones using my bluetooth.
reset your blue tooth , pair it agian with your phone. remove all other blue toohts and pair it again. i hope that works .
Feb 17, 2007 | Motorola Mobility Razor Behind-the-Head...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
