Question about Canon Office Equipment & Supplies
Jet ink canon printer problem - Canon Office Equipment & Supplies
IB4G2008
  • 3587 Answers
SOURCE: Canon BJC 3010 Ink Jet Printer Problem
does it do a test print job?
Posted on Mar 30, 2008
yooperbud
  • 8637 Answers
SOURCE: I have a canon i560
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
SOURCE: Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Posted on Jul 16, 2009
pineworks
  • 4041 Answers
SOURCE: how do I change the waste ink absorber in a canon ink jet printer
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
Printer prints every 2nd or 3rd line of a Word Document in pale gray ghostly way
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Nov 29, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
The black ink is not printing on my canon mp510 even though there is ink.
sounds like the black ink jet is blocked with dried ink, use the maintaince tool, should be in the canon software
Sep 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Printer is saying more then one ink tanks of the same colour is installed. Yellow. Then it is saying it isn't recognising the yellow ink
Do you have all Genuine Canon Ink Jet Cartridges?
If you don't then that could be the problem.
Otherwise, if you do, then I would try another yellow ink jet cartridge from Canon.
Aug 20, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Just refill our black ink for canon pixma ip 1200 and it gives out lines in beetwen image. How can i fix? it says it needs to unclogged but i kept cleaning through maintenance tab and result is still the...
Canon recommends genuine canon ink jet cartridges. If you bought a remanufactured ink jet cartridge and it did this, I would return it immediately.
But, since you filled it yourself, there's no recourse with the ink company, I don't believe.
Even if you were successful with refilling, they can only be refilled 2 or 3 times at best.
Jul 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Hi. No magenta or cyan printing on my canon pixma 750. used the maintenance cleaning function and head refreshing to no avail. Any ideas,thanks Mark
Sounds like the ink jet cartridges need to be replaced. Cleaning will not solve the problem after the ink is depleted, and if the ink were low, the cleaning process uses up a lot of ink.
Good luck on replacing the ink jet cartridges.
Jul 16, 2010 | Canon PIXMA MP750 All-In-One InkJet...
My ink jet did not print
You must change both cartridge. Instead use completely new cartridge Part No 830 black and 831 colour
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Driver
deseo tener los drivers de la impresora canon S200x
jomuroj@gmail.com
Jan 01, 2008 | Canon S200X Ink-Jet InkJet Printer
23 people viewed this question
old marine
old marine
