How to fit new door handle on washing machine A147CR6B
gittos73
  • 244 Answers
SOURCE: Door seal
i will tell u step by step 1)open the door undo the clamp that holds the front of the seal on it is around the lip push door seal back so its out of your way into the drum 2)take the lid of look to the front were your seal is fastened onto the outer drum this is held into place with a screw clamp unscrew it and u should be able to ease the door seal of from around the drum reverse these actions to replace the new 1 i have sent these instructions too 3 other people they have found these instructions easy to follow and do
Posted on Aug 15, 2007
  • 1462 Answers
SOURCE: fitting door seal
this is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Posted on Jun 24, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
Hoover washing machine door handle
if any one is stuck fitting a door handle to a hoover washing machine HNL 6146 nextra series then please email me johndgill49@hotmail.com
Aug 29, 2009 | Indesit W 123 Front Load Washer
Door on Hotpoint WT540P Won't open
I have solved this problem now. I removed the top of the washing machine and opened the catch with a screwdriver to release the door. The plastic handle on the door has snapped so have ordered a new one on line for £5 plus p+p. Should be able to fit it myself. Hotpoint wanted £100 - £160 to come out and fix it. Beware!!
Aug 21, 2009 | Whirlpool Washing Machines
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Door handle of washing machine broken
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Door handle replacement
I tried different ways of putting the door handle and lock together. It took me 5 hours to eventually work it out. Now the problem is solved.
I took a digital photograph of the lock before I put it back onto the machine, so now I have a permanent record to refer to next time. I say next time, because we've had 2 Servis Washing Machines, and between the 2 machines, the door handle has broken 4 times, through no fault of ours, each time having waited for the time switch to deactivate.
I think by now the company ought to make the plastic piece that keeps snapping, out of aluminium.
Sep 12, 2008 | Washing Machines
I have just fitted a new door lock on my washing machine hotpoint wm53p and now it wont work.
How do i replace the door handle on my hotpoint washing machine (wt960)?
Jul 21, 2008 | Hotpoint Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
