Question about Canon Office Equipment & Supplies
How to fix canon printer with continuose ink system
Paper is not printing
Since you are asking about a Canon Pixma ip3500, I would guess that the ink cartridge(s) is/are dried out, empty, or clogged. Try swapping out with new, fresh Canon cartridges and see if that fixes the problem.
Also, be aware that it is extremely ill-advised to use only refilled or "compatible" cartridges all the time in the case of inkjet printers (of which the Pixma line of printers is an example). The reason being that the refilled and "compatible" cartridges use plain ink while the OEM cartridges use a mix of ink and lubricants so as to keep the ink delivery system functioning to peak efficiency and help to keep the system clear of clogs. Therefore, if you have recently put in a new cartridge but it is yet another refill, swap it out for a real Canon cartridge and then try using the "clean the printer" function to try to clear out the ink nozzles. If you don't feel comfortable doing this or you are unsure how to accomplish this task, get in touch with a local computer or printer repair shop and they will gladly resolve this for you.
Jun 05, 2015 | Canon PIXMA iP3500 Printer
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
Apr 15, 2013 | Canon PIXMA MP170 All-In-One InkJet...
Canon mx310 printer has ink absorbor full message and will not print. how do we fix this?
Do you shocked this morning just to find out that Your "Waste Ink Absorber Full" on your Canon Printer? This warning made your printer useless because It cannot printing your works.
You have no money for service or change the waste ink absorber on your Canon. I know it could be very expensive. Don't Worry... I have something that maybe can help your problem. Take it Easy, it's FREE.
Canon Printer Motherboard System, will count how much time you had printing or change the ink tanks. After a couple of times your Canon System (Motherboard on your Printer) will stop your Printer because Canon think you waste ink absorber is FULL. So you need to replace your waste ink absorber to the new one. And It's Expensive For Me. But there is a trick to reset the counter on your Canon printer motherboard;
Step 1: Manual for Service mode (1st method). Using manual way ( but not really effective ), because sometimes your canon will prompt the "Message" again. Here's the trick:
Unplug POWER Cable.
PRESS and HOLD the POWER Button (While Disconnected From The Power Cord).
Connect the POWER Cable (Still Holding The POWER Button).
PRESS The Resume / Stop Button 4 Times while holding the POWER Button.
You'll see the Blinking Led Color keep changing from Orange to Green everytime you press the Resume / Stop Button.
Then Release The POWER Button.
Your printer will turn ON (It should not blinking anymore).
Step 2 : Using Software Tools (Reccomended), It can make your printer Permanent not showing the "Messages" again. Just Download Canon Series Resetter. Here's the Link :
Download Link
Sep 02, 2011 | Office Equipment & Supplies
My printer installation has been done ... CANON ip2770 .... But it is showing some problem with my black ink cartridge .....
Just press and hold down the resume/cancel button (the circle with inverted triangle) and wait until the printer restart.
That should fix it.
Dec 16, 2010 | Canon PRINTER CANON IPF8000S PRINTER...
Just refill our black ink for canon pixma ip 1200 and it gives out lines in beetwen image. How can i fix? it says it needs to unclogged but i kept cleaning through maintenance tab and result is still the...
Canon recommends genuine canon ink jet cartridges. If you bought a remanufactured ink jet cartridge and it did this, I would return it immediately.
But, since you filled it yourself, there's no recourse with the ink company, I don't believe.
Even if you were successful with refilling, they can only be refilled 2 or 3 times at best.
Jul 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Hi, E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you are using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, then Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY.
Follow these steps:-
1.Turn On Your Printer. 2.Wait Till The Printer Led Screen Show The Error Code ( E4). 3.Then Press and Hold Black & Color Button for about 5 - 10 seconds.
It will fix the problem.
Thanks! mannu_rakesh
Sep 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Can I use only a black BJ cartridge on a Canon 620 printer?
Nope. You can use Cyan, Magenta and Yellow as well as Black.
Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    Refilled ink cartridges not recognizby printer.
    I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
    Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
    I have the same problem and my power will not turn on if the resume button is depressed. Is there a way to fix the waste ink problem?
    Feb 06, 2008 | Canon MultiPASS F60 All-In-One InkJet...
    24 people viewed this question
    old marine
    old marine
