Question about Boating
I am looking for the engine number on my PERKINS PRIMA 80 MARINE but have looked everywhere can only come up with WFM1875NW
5 Suggested Answers
Mysted
  • 15 Answers
SOURCE: three-digit code for prima tv for universal control
If you can't find it under prima look under legend
If not read your manual and depending on the remote you have a option for the remote to find the code by itself
Just have to follow the instuction in the remote user's guide in the place that says "Brand not listed"
Good Luck
-John-
Posted on Dec 30, 2007
  • 58 Answers
SOURCE: I AM LOOKING FOR THE CYLINDER HEAD BOLT TENSION
hi 75 lb/ft silk090
Posted on Oct 24, 2009
  • 6 Answers
SOURCE: Looking for MAGMA marine Kettle Gas Barbeque floor stand
call SoPac for a dealer near you
Posted on Jan 21, 2010
mrstanskaggs
  • 118 Answers
SOURCE: how and where do i find the usb wires for my photo keychain. i have looked everywhere
it is either a micro-USB or mini-USB connector.. mini is thicker. It has to be one of these two.. if you do a search, you can see what they look like.. remember: Mini or Micro.
Posted on Jan 10, 2015
What year is my MF 40 with 3cyl perkins diesel engine And what the engine number would be, trying to find a injection pump for it. Thanks
3 cylinder Perkin diesels were used for a long period of time in MF units
the mPN is HTS0391- alternate numbers -3639020M1
any accredited diesel specialist shop will be able to get you one or be able to repair and recalibrate your unit
you can mention that it is out of a MF tractor but the details that you want are a 3 cylinder Perkins engine
The original brand is CAV but there are other makes available
Sep 11, 2017 | Cars & Trucks
How to remove starter from a 4 cylinder perkins engine
Search Results
    [PDF]Perkins 4-154 Shop Manual
    www.kp44.org/ftp/Perkins_4-154_Shop_Manual.pdf
    88 Perkins. Engines workshop manual. 4.154. PRINTED lN U.S.A. .... removal, dismantling, assembly or refitting of a part is straightforward ... The ENGINE NUMBER is located on the cylinder ... starter motor, air cleaner, but without clutch. lb kg.
    Reliability built into starter motors - Perkins Engines
    www.perkins.com/en_GB/.../starter-motors.html
    Perkins EnginesYou can rest assured that your genuine replacement starter motor will work ... 4 Cylinder ยท 6 Cylinder ... You can learn more about these cookies and general information about how to change your cookie settings by visiting our Privacy and Cookies page. ... This need for dependability is why we test each of our starter motors.
Dec 25, 2015 | Cars & Trucks
Was told by a marine mechanic that put a camera into spark plug hole that lower piston is scored and motor is rusty
well scored pistons will run but have little to no power , depends on how rest of boat looks , well stocked boat yards can pull old engines out (they use same crane as picking up boats) then you can send it out to be rebuilt correctly as only then can a good decision be made to weather to scrap it or not when after a experienced engine builder has a look at it he makes the call
most mfg like perkins/.yanmarr and mercury do offer half blocks for retrofits as well could be way cheaper to go that way too
May 07, 2015 | Boating
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
I cant find the engine number
Please take a look at below link.The pdf will help you to locate your engine number.
http://www.perkins.com/cda/files/287332/7/engine_number_guide_english%20issue5.pdf
Oct 29, 2012 | 1998 Mitsubishi Montero
Trying too establish what year this motor is it a 2 stroke 80 hp 6hoL450289 yamaha outboard motor.
Try contacting Yamaha direct or a reputable outboard dealers for the address, they will point you in the right direction, like all motors manufactured the makers keep a record of the serial number, i recently tracked this down for a friends Perkins Diesle engine that is running a generator in the middle of Spain, it turns out that his engine came from a 1912 lorry.
Good luck
lacala69
May 14, 2011 | Computers & Internet
SANDERSON TELEPORTER, HOW DO I BLEED THE LUCAS FUEL PUMP ON A PERKINS ENGINE
Perkins is a hard engine to prime. Fill the fuel filter with clean diesel, there should be a hand pump on the left side(looking at the front of the vehicle) . There should be a bleed screw on top of the filter housing. Loosen the bleed srew and pump the hand pump untill you get a steady stream of fuel from it. Tighten the bleed screw. Loosen the injector bonnet nuts approximately 1 1/2 turns on all of the injectors. Turn the engine over until you see a steady stream of fuel from the the injector bonnets. Tighten the bonnet nuts, pump the handpump approx 10 times and start the engine. Give it half throttle until it stops stumbling and all of the air is worked out of the system.
Jan 08, 2010 | 1985 Mitsubishi Pickup
Three-digit code for prima tv for universal control
Good Luck
-John-
Dec 29, 2007 | Televison & Video
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
