Question about HP iPAQ rx5915
Active Sync Installation not recognizing Outlook on PDA
During install of Active sync (ver4.5) I am notified I will not be able to access outlook items (on PDA).
The message says I must install and run Outlook to be able to sync outlook items with PC.
Note that active syc works very well for moving files.
How do I resolve? Outlook messages and contacts are installed on PDA.
and I would like to sync with Contacts.
  • 4 Answers
Remove the Activesync software...reinstall it.
Thats the best and fastest suggestion I can give you.
I have the same problem off and on.
Posted on Nov 26, 2007
How to sync palm data with Itouch? I have all my contacts & calendar on my Palm Zire. How can I get the same data over to my I touch in a Windows XP environment ?
You can sync to Outlook on the PC and then get the Outlook data onto the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item where you can switch between Palm Desktop and Outlook. If you no longer have the original install CD or have an older device Pocket, Copy from It will move the Palm Desktop records to Outlook.
Mar 08, 2010 | Palm Zire 31 Handheld
Ipaq h2210 won't sync with desktop
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Aug 13, 2007 | HP iPAQ H2210 Pocket PC
I cannot sync my Palm Tungsten E with MS Outlook.
  1. Step 1 Install the Palm Tungsten software. This software is required in order to sync Palm Tungsten with Outlook Express. To install the software, place the CD-ROM in your PC and follow the on screen instructions.
  2. Step 2 Use the HotSync cable included with your Palm to plug into the USB port of your PC. You will then plug the other end of the cable into your Palm Tungsten.
  3. Step 3 Open the HotSync Manager program on your PC through the "Start" menu or clicking on the icon. You can manage the different programs available for synchronization through this program. Select Microsoft Outlook as one of the applications that you want synched onto your Palm Tungsten.
  4. Step 4 Turn on the Palm Tungsten. You will see a star icon on the menu of your PDA. Tap this star with your stylus to start syncing Microsoft Outlook Express. A dialog box will appear on your PC during the process to know the progress of the synchronization.
  5. Step 5 Unplug the cable from your PC and Palm Tungsten once the sync is completed. As the Palm resets, you will now notice that Microsoft Outlook Express is available on the PDA.
Jun 25, 2009 | Computers & Internet
HP Jornada 548 files won't sync with Vista PC
No need to! all u need is to download windows mobile device centre at:
that should help you!please do rate if it does,regards!
Nov 21, 2008 | HP Jornada 548 Pocket PC
Not able to sync
just download the Microsoft ActiveSynk and then you will be able to connect your PDA with computer without any problem.
here is link for ActiveSynk 4.5 and it is 7.5 MB in size
all the best
Was this solution helpful? Show your Appreciation by rating it:
Feb 05, 2008 | Samsung i760 Black Phone
Switching to the MS Outlook Conduits using the Palm Installation CD
Search Installation Disk, I had this same issue. The Outlook conduit is on the installation guide, you have to search for it. 1. Insert the installation disk. 2. Open My Computer 3. Right click the drive that contains the disk. 4. Click Search. 5. Enter the conduit name for your device (ex: Pocket Mirror) 6. The search results should contain the executible file that you need to run to sync with Outlook. Hope this helps.
Sep 13, 2005 | Palm Tungsten C Handheld
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Does the ipaq 2215 work with Outlook 2002?
Active Sync will work with many version of outlook. Your PDA interfaces with Active Sync. Certain versions of Windows Mobile software and/or PDA's require higher versions of active sync to sync correctly.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
I have PalmIIIxe. Is there a way to sync with Outlook using my PDA?
Yes - the software was included. Your CD software allows you to select synch with Palm Desktop or synch to Outlook. As long as Outlook is installed on the PC, the CD software installer will see Outlook and offer you this option. So the answer to your question is - reinstall the software and take the option to sync with Outlook when it is offered. PS just in case you have Outlook Express, this is not the same things as full Outlook. Outlook Express requires third-party software for synchronization of its email database and of its addressbook (actually Windows Address Book WAB format).
Sep 11, 2005 | Palm IIIxe Handheld
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
HP iPAQ  rx5915 Logo
266 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
