Question about Pioneer Audio Players & Recorders
My Pioneer VSX-D514 receiver/amplifier won't power on.
I have unplugged it and plugged in again and pressed ENTER and ADVANCED SURROUND many times but nothing happens. This has worked previously, but not this time. Any other suggestions?
  • Alexander Poor May 13, 2017
    I have taken it to an authorised Pioneer service company who knows the product.
    New Friend:
    Problem Solver:
  • 15 Answers
Maybe something's wrong with the amplifier board or something else, it probably needs to be repaired by a professional or a manufacturer that owns the product.
Posted on May 13, 2017
Testimonial: "I have taken it to an authorised Pioneer service company who knows the product."
    Top Expert:
  • Pioneer Master
  • 40,417 Answers
An internal fuse may have opened.
Posted on May 09, 2017
Testimonial: "Thanks for the suggestion. I will disconnect the components from the back and take it to the repair shop and tell them this."
  • Alexander Poor May 12, 2017
    I took it to the AV repair shop and they said it most likely is not a fuse, however, it was discovered that the voltage switch knob in the back had fallen out and a small part of it broken, so they are probably going to look in that area for a problem. Will reply again when I pick it up and let you know what had to be repaired.
VSX 60. MCACC blue Light flashes and unit will not turn on
try pressing and holding 'advanced surround' and the power button. This should reset the protect circuit. If it turns off again right away, then there is a problem with the amp that needs to be repaired.
Mar 25, 2014 | Pioneer VSX-52TX Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Mar 07, 2008 | Pioneer VSX-D514 Receiver
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
85 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
