Printing a voucher - Computers & Internet
How do I get my vouchers
possibly a scam we know of no vouchers . check with site that offered them
Aug 14, 2016 | Luggage & Travel
Cannot print my voucher,please send it as an e-mail to kpahocsa@hotmail.com voucher #8560-3791
sadly you need to send this request to the proper place . not to fixya
Jan 29, 2015 | Computers & Internet
How do I copy a pizza express voucher onto a memorystick?
When you open up the page for the voucher just click in on the file tab located at the upper left corner of your screen, click the file tab then choose "save as" and save it to your memory card, you should insert your memory card to the memory slot of your computer , if your card is not fit then you should have a memory card reader to connect your memory card.
you can also do the copy paste and the print screen procedure
Nov 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Voucher checks not printing correctly HP C7280 AIO
The front of your voucher check is smoother than normal paper or the rear of thr voucher. Cleaning the feed rollers should fix this problem. If you do not know how to clean the rollers, you need to take the printer for a service.
Aug 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
Printing Quickbooks voucher checks with HP 6500 officejet printer
i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
May 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Laserjet 1022 does not print the full date in voucher
adjust the page setting through pagesetup .and then check out in the print preview first before giving the print command.
Dec 10, 2008 | HP LaserJet 1020 Printer
Tally Voucher printing
see just go start setting and printer in printer right click go to server properties in that you will get option of creating form choose new form and give the sige of voucher so whenever you printing voucher select this paper size. bye
May 29, 2007 | Epson LX-300 Matrix Printer
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
