Question about Miele Freezers
How can I order a Fitter for my F1413SF Miele 18'' All Freezer,Pr 10/07/15?
Replace the old fitter for my freezer.
4 Suggested Answers
  • 40 Answers
SOURCE: the fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Posted on Jul 01, 2009
sparktgo
  • 68 Answers
SOURCE: Frigidaire upright freezer is making whining,
If all is working fine otherwise ,check the fan in front of the condenser.It may just be the wear in the fan bearings.A replacement fan would be all thats needed to fix then.
Posted on Oct 14, 2009
Testimonial: "Prompt response. This would be the best possible solution! Thanks."
SOURCE: I have 20 cf Whirlpool
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Posted on Nov 20, 2010
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
What do the red light with abell shape which is lit up mean on my 18 year old tricity bendix freezer mean
It's a temperature warning that the freezer is no longer at the correct temperature. Check all is clean and working, door seal intact etc. If short of gas, probably time to get a new one!!! Bet it won't last 18 years this time though!
May 01, 2014 | Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Miele freezer The fan on my standalone Miele
Hello David Riome,
Why are you discovering a FACTORY ASSEMBLY
does not fit ...??
(just be sure... KITCHENAID was one of my worst).
and keep in mind...
ALUMINUM only bends a very few times before
it breaks (soft, brittle & very difficult to repair).
((protect it)).
The FAN must be free of all obstructions to function.
If it is out of balance, worn or broken in ANY WAY...
REPLACE IT...
Make sure all wires and lines are ABSOLUTELY
NOT in contact with the fan bracket...
(secured out of the way).
Most of these newer units have aluminum evaporators
and a FAN BRACKET will easily wear a HOLE in
your REFRIGERANT LINES.
Like a saw... It may take a couple of years but
sure as winter follows autumn... $$$$$ damage
from conflicted refrigerant lines.
Move the wires and lines away from the FAN.
Carnac the Magnificent
May 13, 2017 | Miele Freezers
My new compressor is noisy
Sure it's the compressor, not a condenser fan hitting on something disturbed when you had the new compressor fitted? If it is the compressor, get the fitter to replace it under warranty.
May 08, 2012 | Arctic Air 22 cu. ft. Commercial Freezer...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
The thermostat has risen to 30 degrees although we
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 23, 2010 | Miele 3.80 cu. ft. / 108 liter Upright...
Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
55 people viewed this question
Top Miele Freezers Experts
John Tripp
John Tripp
Jay Finke
Jay Finke
ray gallant
Are you a Miele Freezer Expert? Answer questions, earn points and help others
