Question about Cell Phones
How do i adjust the timing on a 1989 nissan pickup truck 2.4L using a timing light what is the number?
I want to check the timing but i don't know what the number is to set it on.
  • michael vanier May 09, 2017
    Hi Joe Russell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?..http://www.infamousnissan.com/forum/show...
  • Joe Russell May 09, 2017
    when i am cranking the engine sometime it seem to kick back or turn slow i just thought i may need to adjust the timng or check it.
    New Friend:
  • 16 Answers
It sounds like your timing should be set on 2 degrees before TOP DEAD CENTRE TDC try it, as it is now youu must be round about 5 deg that is why your engine is kicking back against compression
Posted on May 09, 2017
    when i connect my timing light to number 1, plug wire do i have to disconnect anything?
Do a 1989 nissan pickup truck D21 2.4L have and check engine light?
No it doesn't have one,too old for the newer feature.By the way I have a mint 85 Nissan 720 4x4 with the 2.4 with Weber.We are old school riders.
Jul 23, 2017 | Nissan Cars & Trucks
What is the ignition timing for 2002 nissan hardbody 2000i 16v
Here are the 3 engines listed for this year. IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 2.4L SFI 4cyl
The Ignition Timing
18-22 DegreesBefore top dead center - When throttle positionsensor disconnected and using suitably programmedscan tool.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (750-850 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (700-800 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI SC 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chockdrive wheels, curb idle speed (700-800 RPM)transmission in neutral.
Jun 05, 2015 | Nissan Hardbody Cars & Trucks
I have a 1989 Toyota Pickup 22RE Engine 5 Speed Manual Transmission - The problem is that the clutch slips on higher gears especially on cruise control when I encounter a hill. Can you tell me if there is...
If it's a hydraulic operated clutch, as I think it is, then no, there is no adjustment. Only the cable operated clutches were adjustable. But there is a clutch pedal height and free-play adjustment that needs to be correct. Freeplay distance is 3/16 to 5/8 inch, adjusted at the pedal end of clutch pushrod. I don't know the pedal height for your pickup (you'll have to ask some toyota person), but the adjustment is made near top of pedal where it contacts the stopper bolt.
Nov 07, 2011 | 1989 Toyota Pickup SR5
1989 nissan pickup
Try having the idle control checked out. It also could be a speed sensor.
Sep 22, 2009 | 1997 Nissan Pickup
We changed head gasket on 1989 d21 nissan pickup now it will not crank it fires but will not start
did u take off timing belt? if so then its not timed if not then check the cylinders for compression. might b a bent valve in the head
Jun 05, 2009 | 1986 Nissan Pickup 4WD 1986
Problum with 1989 nissan truck...
maybe the motor gave up the ghost....
Jan 23, 2009 | 1993 Nissan Pickup
Cell Phones Logo
1,646 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
