My smartload menu has been locked,how can UNLOCK my smartload menu?
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Tip
Samsung LCD monitors Lock-Unlock instructions
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
on Apr 23, 2010 | Computers & Internet
Said in smart may smartload menu is blocked how to fix them?
To update your Smart Load Menu, just type the syntax/keyword and send it the access code.
For example, text PULL (space) MENU to 343.
Here's a list of the keywords/syntax:
Brand Syntax/Keywords Access Code Buddy Load Menu PULL<space>MENU Cignal Load Menu CIGNAL PLDT Load Menu GETPLDT Red Mobile Load Menu GETRED Smart Bro Load Menu GET<space>BRO TNT Load Menu PULL<space>MENU For successful menu updating, please take note of the following:
  • Account must have at least P1 airtime.
  • Phone unit must be idle for 20 minutes, with screensaver and keypad lock temporarily turned off.
  • Signal must be stable with 3 - 4 signal bars.
  • If your phone prompts "allow to send the messages", press Send.
Nov 12, 2013 | Cell Phones
I forgot my Smartload PIN
Pin I forgot i want reset
Jul 15, 2012 | Cell Phones
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
lock function.
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
Ddigital voice recorder rp5022b
The only way to unlock is to hold the menu button down for three seconds. This will lock or unlock the recorders functions.
Apr 25, 2008 | RCA RP5008 Handheld Digital Voice Recorder
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
