Question about Brandt Washing Machines
Brandt washing machine c03 - Washing Machines
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
  • 6277 Answers
SOURCE: I need user manual for
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct and there are often tabs on the Fixya site;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 15, 2011
SOURCE: brandt wtd 1276k washing machine error d23.?
You need to reset the thermostat that's inside the washing machine, it's on the right side.
Check HERE for details and photos
Posted on Sep 20, 2012
My Brandt front loader washing machine has a locked red padlock showing and the machine will not function
Have you tried holding in the Start/Pause button for at least 3 seconds. Sometimes doing this twice rectifies the problem
May 18, 2015 | Brandt Washing Machines
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
go to and get the support via ONLINE via chat or phone.
God bless you
Sep 25, 2012 | Washing Machines
Instruction Manual for Brandt 8625 Bill Counter Money Counter
I found this site while looking for manual for brandt bill counter, but it seems to be about washing machines. Does anyone have a manual for the bill counter?
Jan 03, 2012 | Washing Machines
We just used a brandt washing machine for the first time. It worked alright but did not take washing powder and fabric conditioner. Could you tell me reason why please? Model type of w/machine is...
used a brandt washing machine for the first time. It worked alright but did not take washing powder and fabric conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 12, 2011 | Brandt Washing Machines
Brandt wtd 1276k washing machine error d23.?
Jan 08, 2010 | Brandt Washing Machines
Problem with Brandt WBD1211 Washer/Dryer program 2
Jan 07, 2010 | Washing Machines
Commant je peux trouver la type de ce modele,etant donne que ni sur son exterieur ni sur son interieur rien n'est marque.Pouvez-vous in'indiquer ou cela pourrait etre ecrit ? thanks in advance giwrgos...
lucky to find info from YOU TUBE; '' Identtifying model,number on washing machines....'' wanted information is hidden behind the pump cover on a self-adhesive label of my Brandt washing machine. thank you for your willingness and fast response; g.florides
Dec 09, 2009 | Brandt Washing Machines
Washing Machines Logo
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
john mabry
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
