Question about Xerox Office Equipment & Supplies
Xerox workcenter 5755 contrast print quality code
  • 2072 Answers
SOURCE: how to setup secured printting
Solution: Send a Secure Print Job From a Workstation bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. With your document open in the application, click on [File] on the toolbar and then select [Print] from the menu. The Print window will be displayed.
  2. Select the printer in the Name field.
  3. Click on the [Properties] button.
  4. Click on the [Paper / Output] tab.
  5. Select [Secure Print] from the Job Type pull-down menu.
  6. Click on the [Setup] button (just below the Job Type menu) and enter a 4 to 10-digit code, to release the job at the printer, in the Enter a 4-10 Digit Secure Print Passcode field.
  7. Enter the code again in the Confirm 4-10 Digit Secure Print Passcode field, and then click [OK].
  8. Make any other required selections in the print driver and the click [OK] twice to send the job to the printer.
Solution: Enable Release All for Secure Print bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution as it requires knowledge of the network’s Authentication environment.
The WorkCentre Pro will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address).Before you begin, print a Configuration Report and make sure the WorkCentre Pro has an IP address, and the HTTP protocol enabled. See the Related Items below.
From the workstation:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to open an Internet Explorer browser window.
  2. Enter the IP Address for the WorkCentre Pro followed by /diagnostics/secureReleaseAll.dhtml in the Address field, and then press [Enter] on the keyboard. For example, type: xx.xxx.xxx.xx/diagnostics/secureReleaseAll.dhtml (where x represents the IP Address). A Secure Print Release All window will be displayed.
    NOTE: The URL is case sensitive; secureReleaseAll must contain a capital R and capital A.
  3. When prompted, enter the username and password in the fields provided.
    NOTE: The default username is admin and is case senstive. The default password is 1111.
  4. Click on the check box next to [Enable release of all secure print jobs with the same user name and passcode] to insert a check mark.
  5. Click on [Apply].
  6. Click on the [X] in the upper, right corner to close the browser window.
Posted on Oct 04, 2008
  • 2072 Answers
SOURCE: I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Posted on Jan 25, 2009
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
That is a business quality, network, workstation. You would be advised to have it professionally serviced once a year.
If you want to try and do some work your self, all the documentation on it is here. The only thing I would suggest is taking the toner cartridge out and tapping it sharply whilst rotating it laterally. Sometimes the toner can cake and not fall down to the developer roller. There is software on the site too.
http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/documentation/enus.html?operatingSystem=win8x64&fileLanguage=en
Apr 26, 2016 | Xerox Office Equipment & Supplies
Inside yellow
please i need how activation code xeror 7120 workcente
Jan 14, 2014 | Xerox WORKCENTER 6505DN COLOR LASER MFP,...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
