How do i clean inside patton puh680? - Heating & Cooling
  • 1015 Answers
SOURCE: CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON
I do not know if this heater is on any product recall but we have used patton heaters for years and pretty much have had good luck with them. However there is a fire hazard present if you set or store combustibles to close to the front.Tip over switches don't always work and I would never recommend using a heater of this type in a unsupervised area.I hope this is of some help to you. Thank you and happy holidays.
Posted on Dec 20, 2010
heatman101
  • 43501 Answers
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Posted on Jan 16, 2011
  • 96 Answers
SOURCE: Are there replacement knobs for
purchase at grainger or johnstone they will be alittle different /generic
Posted on Mar 05, 2011
  • 4736 Answers
SOURCE: We are having a discussion at our Plant on the
Must be an older model heater. All the recent ones have a 3 prong plug. Especially, since the recall a couple of years ago on the PUH680-U Heater.
Posted on Jun 21, 2011
SOURCE: I need the lighted switch on front of Patton
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
Are the thermostat knobs replacable?
Yes, they should have a set screw built in, or they will simply pull off without much effort. If the knob does not pull off without much resistance, then look around it for a hole with a allen screw inside. If this is the case, just loosen the screw and the knob will come off no problem.
Mar 03, 2011 | Patton Electric Patton PUH680-U Electric...
Shuts off after 15 mins
its hitting the high limit temperature switch...
is the heater clean inside? clean any dirt or dust off the fan blades and vent grills.
Is the fan turning and running at proper speed?
Jan 07, 2011 | Patton PUH680-U Utility Heater
CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON RECALL PATTON PUH680-U
Dec 20, 2010 | Patton PUH680-U Utility Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
A small, white, plastic or ceramic part which
TRY AN APPLIANCE STORE THAT DOES REPAIRS. OR CHECK ONLINE WITH MANUFACTURER OR IF SOMEONE CARRIES PARTS FOR IT ONLINE
Feb 26, 2010 | Patton Electric Patton PUH680-U Electric...
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Nov 12, 2007 | Patton PUH680-U Utility Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
