Question about Hotpoint Washing Machines
Hotpoint g-162 washer issue. the ares behind the knob will not turn anymore. how do I replace. What part do I need?
4 Suggested Answers
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
SOURCE: GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Posted on Dec 20, 2009
  • 266 Answers
SOURCE: i have a hotpoint ,
Some of the old washers have a delay between each cycle that seems long but less than 2 minutes. If this is not the cause you will need to order a new timer not the knob. Sorry if its very old it may not be worth it.
Posted on Aug 16, 2010
Replace control knob on hotpoint AQ9L 29 I
Hi
open the door and you will see a cover at the top held on by about 6 torx head screws behind this is the control panel display panel
remove this panel and replace it as some of the knobs are not replaceable
Jun 11, 2016 | Hotpoint Washing Machines
How do I remove the timer knob on a hotpoint washer model vbsr2080woww
i think thiers a pop of cover on front of knob and a 2ba nut behind same
Oct 12, 2014 | Hotpoint Washing Machines
Hi, I have a Hotpoint Aquarius WF530 washing machine. When I put on a wash program I hear the pump running as per normal part of cycle but nothing else happens. Drum does not fill with water... If I turn...
most probally the control module (bottom of machine) emw electronics are your best bet for a replacement, as otherwise they have to be programmed by hotpoint
Sep 09, 2013 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
I have a hotpoint , heavy duty large capacity washer and it runs but after each cycle , you have to manualy turn the knob to next cycle for it to work ,it is an older washer but does it just need the knob...
Aug 16, 2010 | Hotpoint Washing Machines
How to replace the selector control knob on a Frigidaire front load washer Model FWT449GFS2
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
Jun 05, 2009 | Frigidaire FWT449
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Aug 02, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
