Question about Relic Watches
How to pop the back back on a relic watch/ take the back off
I have a pink plastic banded relic watch, I finally got the back off and replaced the battery. Now I can NOT GET THE BACK TO SNAP BACK ON!! ALSO: I have a white square faced relic watch that I cant get the back to pop off of.
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
SOURCE: HELP !! can't snap armitron watch cover back on
Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
Posted on Sep 22, 2008
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
kaicooper
  • 8 Answers
SOURCE: back of watch won't snap back on
that is a common problem...
Posted on Jun 19, 2009
I have a Relic watch that is probably 20 or 30 years old. It still runs well, but the bracelet band is broken. I live in Monroeville, PA. Where can I get the band replaced?
mcdevito75 Here, You can go to Ebay or simply look for a small watch repair shop in your area for a new Bracelet for your Reic watch.
Sep 24, 2010 | Relic Watches
I have the Relic with the pink face which stopped working. The watch repair at Sears said not the battery, it's the mechanism & wanted $60 to repair. Can I send it back to Relic?
<P>Thank you for cxontacting FixYa.</P><P>You can send back to Relic. I dont know how long you have had, as they do have a 12 yr warranty but you will have to see what restrictions they have on it.</P><P>You can find this info at:</P><P><A href="http://relicwatch.com/warranty.htm">http://relicwatch.com/warranty.htm</A></P><P>Best wishes. Jewel</P>
Aug 27, 2010 | Relic Glitz ZR11778 Watch for Women
How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Jan 09, 2010 | Relic Watches
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Need to adjust watch band
how to adjust a man's beverly hills polo club watch band
Aug 23, 2008 | Relic 0504648FA
Need to replace band on Relic ZR50003/1200607 watch
Hi i need to change the band in my watch any idea how to do it ?
Many Thanks
Wiola
Mar 11, 2008 | Relic Watches
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Feb 14, 2008 | Relic 0504648FA
Tools:
Procedure:
Nov 05, 2007 | Relic 0504648FA
Watches Logo
Top Relic Watches Experts
Andrew Taylor
Andrew Taylor
richie46
Are you a Relic Watch Expert? Answer questions, earn points and help others
