Question about Ovens
Inside glass of WVE665S has shattered. Can it be replaced by us or do we need to call repair person? Also, is this a 'common' problem - its a rental property so not sure if it has been misused.
  • Ken Adams
    Ken Adams Jul 20, 2017
    I got mine from Genuine Appliance Parts dot com dot AU. Its easy to replace, the oven over heated and the glass broken on the grill door.
Krazytech
  • 725 Answers
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: kitchen aid oven door glass shattered
gget a new door
Posted on Jun 21, 2009
rtpflh
  • 546 Answers
SOURCE: I have a smeg self cleaning oven on the first
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
Posted on Sep 23, 2009
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Feb 22, 2010
Testimonial: "thanks"
barkencoa
  • 3463 Answers
SOURCE: the outer glass on my hotpoint oven door has
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Posted on Nov 11, 2010
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
Oven glass door shattered on the inside during self clean mode
The glass is replaceable. You need to get the exact glass replacement kit from the manufacturer. I had to have mine replaced about a year ago due to condensation between the 2 glass panels and was able to get the replacement for $0.00.
Suggest to Siemens that the glass on yours should not have shattered and therefore was probably defective and you may luck out and get the glass for free. It's worth a try.
Mar 18, 2010 | Siemens Ovens
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
Electrolux EOG9330 Oven Door Glass shattered!!
It is quite common for this problem to occur.
There is no one satisfactory explanation for this to happen, but happen it does.
DO NOT use the oven until you have it repaired.
Contact the makers or one of their repair agents to get a new door glass fitted.
Hope this helps, and in the meantime have a nice xmas, go out and let someone else do the cooking for you..
Merry Xmas.
Dec 25, 2009 | Electrolux EOG9330 Gas Double Oven
I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Sep 28, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
