Question about PRINTER Office Equipment & Supplies
My printer is hitip510k. It is giving me error code 26. How can I repair it? thanks
3 Suggested Answers
dbarchitect
  • 150 Answers
SOURCE: konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Posted on Dec 11, 2007
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Konica 7020
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Error code 26
You have a clog some where
F26
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Front Load Washer Repair Not Draining or Spinning How to Unclog the Drain...
May 31, 2012 | Maytag Washing Machines
How to repair Canon pixma MP198 error 5
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 25, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Jan 12, 2008 | Canon imageRUNNER 400S Copier
Error code problem
you did not specify what machine????
go to my site under error codes and look for your machine and you will mosre than likely find what it means/
http://checkitright.spruz.net/main.asp?page=dp&dis=834222
Dec 07, 2007 | Office Equipment & Supplies
Error Message F-26-3
developer most likely needs to be replaced
Nov 16, 2007 | Office Equipment & Supplies
26 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
