Question about Sony Televison & Video
My RCRN04GRRCA 4 Function Prog.RemoteCntrl.It. prog. fine 4 $10 Sony usedBlu-ray DVD playerBig Spender !!. Only 1 issue, no EJECT button.Walk 2 the console button? In 2017? Really? Geoff
RCA RCRN04GR 4 FUNCTION PROGRAMMABLE REMOTE CONTROL Can I add an eject function to some button, as no eject button is there ?
sharcnet
  • 2130 Answers
SOURCE: VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Posted on Jan 28, 2008
SOURCE: eclipse ucnv 884 not function
changing the lanuage from Japanese to english
Posted on Aug 29, 2009
  • 7 Answers
SOURCE: I installed windows 7 and now my function keys don't work
You need to install the drivers, windows does not recognize these additional buttons until the proper drivers are loaded. Depending on manufacturer windows 7 drivers may or may not be available. Microsoft did something smart with windows 7 by allowing you to use windows vista drivers in windows 7. So if there are no win 7 drivers just download and install the vista drivers. Good luck!
Posted on Dec 04, 2009
SOURCE: Comcast remote codes for Sony Bravia DVD Home Theater System
This Also Works for DAV-HDX598w
Posted on Feb 19, 2010
steven_mower
  • 9 Answers
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Posted on Jul 21, 2010
Why my blue ray dvd BDP-s185 cant eject disc. it say '' the eject key is not available''
you might have the tray lock function turned on. TRy holding the play button for about 10 seconds to see if it unlocks
May 06, 2014 | Sony Bdp-s185 Blu-ray Disc Dvd Player...
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
How do i turn off the sound on the alarm
Setting Audible signal
This function gives an audible signal when the coffee is ready. The factory setting is "On".
  • The display (q) will show " " with the current time.
  • To turn off the audible signal :
  • Press prog button then the 1 - 3 cup button (p).
  • The display will show "YES": indicating the audible signal is on.
  • To turn the audible signal off:
  • Press the 1-3 cup button again.
  • The display will show "NO": the audible signal is off.
  • Press prog button to confirm.
Sep 24, 2010 | Krups FMF5-14 Stainless Steel 10-Cup...
Govideo model dv2130
You should be able to get into a list of timer recordings by this method:
1 Open “Initial Setup” menu
Press the SETUP button or the TIMER button while the DVD is in
Stop or Play mode.
2 Select “PROG”
Use the ??/?? buttons to highlight “PROG” then press the
ENTER button.
3 Select the recording to be deleted
Use the ?? and ??/?? buttons.
Press the ?? button to move to the next setting.
The squares are the arrow keys! You should be able to delete the settings using these keys or some other key.
Next time you set a timer recording make certain you don't set the weekly setting!
Apr 29, 2010 | GoVideo Go Video DVD/VCR Combo
KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
