Question about Panasonic Televison & Video
Picture has become too large on my panasonic DMR-EX 78. Have tried reset, still there. TV is ok so not that.
Problem on watching tv thru it, hdd & dvd. Aspect ratio is 16:9. Looks like it has zoomed but can't find any way to control this. Thought I had leaned on remote but can't find solution.
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
ward_knutson
  • 64 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
You cant change the aspect ratio. Polaroid built this unit with a non-standard format. Here is what I found:
Don't be thrown off by other wide-screen aspect ratios. When shopping for wide-screen displays--especially flat-panel LCDs--you may see aspect ratios such as 15:9 or 16:10. They are, for all intents and purposes, close enough to 16:9 to be considered synonymous. Unless you're extremely sensitive to geometry, it's doubtful you'll notice the slight stretching or squashing they introduce.
Sorry!
Posted on Nov 25, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
SOURCE: How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Posted on Sep 22, 2009
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The...
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
Nov 02, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EH50. Dubbing NTSC VCR tapes to HDD
That's normal with different region signals. Only a multiregion recorder/player combo will transfer properly
Jan 03, 2008 | Panasonic DMR-EH50 DVD Recorder
Panasonic recorder
Have you checked your cables? Start resetting one unit at a time until you isolate the culprit. Don't forget the simple unplug all units to let them reset. .
Panasonic DMR-EH55
Motorola 6416 DVR
Sony STR-DA5000
27 analog tv!
Sony 5 Disk DVD Changer
5 speakers
PC connected
You think I have fun when something hiccups? A software snaffu? Bad a/v cable? Loose speaker wire? By the way-my online support is getting better and better. Charter cable has live chat, as does Sony and Motorola. Good luck. Also, I can't think of a single setting I've changed with the Panny. other than assigning digital audio out settings. DEcoder setting? Your Panny?
817-230-4017 if you haven't fixed it.
Dec 09, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
