Question about Electrolux Washing Machines
My electrolux ewf1074 counts down until it finishes its cycle. Does not wash at all. When finished machine just has the time on screen that was the starting time for the cycle. Door wont unlock.
SOURCE: Hoover Washing M/C Door Jammed
we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
Posted on Dec 31, 2008
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
  • 6 Answers
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
SOURCE: Hotpoint WML560. door release wont work after wash
my niece pressed all the buttons on the machine now it will not start any cycle
Posted on Jan 18, 2011
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
How do I turn off the beeping noise on the Electrolux 7kg Time Manager washing machine the 5kg Electrolux Sensor Dryer? The beeping noises indicating a cycle has finished are very loud. Please help!
The acoustic signals operate when:
• The programme is completed.
• The appliance has a malfunction.
To deactivate/activate the acoustic signals, press "Drying level" and "Prewash" button at the same time for 6 seconds.
If you deactivate the acoustic signals, they continue operate when the appliance has a malfunction.
Dado
Mar 06, 2016 | Electrolux Washing Machines
Why the time would be change after the completion of wash ?
washing machines use a timer for the wash cycle
if your model has a clock as well then when it starts it moves to count down until the wash is finished the the clock switches back on at the right time
your question is very ambiguous
Jan 31, 2016 | Washing Machines
Electrolux ewf1074
check the micro switch on the door
Jan 24, 2014 | Washing Machines
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
Apr 26, 2012 | Electrolux Washing Machines
I want a manual for an electrolux ewf1074 front loader
http://www.electrolux.com.my/Files/Malaysia_Singapore/Manuals/FabricCare/EWF1074.pdf
Jan 03, 2010 | Electrolux Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
